For MSL > 1, you have bake the components for a certain period before assembly, otherwise you will have popcorn components. AFAIK, most standard SMD LED are MSL 0, so no baking.
For the drawers, You can use some silica gel or similar hygroscopic material (Usually found in component packages or other sensitive equipment such as hard drives).
