Re: 110/220 LED bulbs
and run relatively cool to the touch.
Did I miss the last innovation cycle?
All the bulbs I'm running and have in reserve have a giant freaking heat sink, and will burn the shit outta ya.
Do you mean relative to an incandescent? Even the last CFL's I installed run cooler than the last LED's I have. Currently have a mixture b/c I'm not going to toss any prior to LED tech just to say I'm running LED's, except for the case when changing a bulb requires a ladder, and there are multiples of them, so they get swapped while the ladder is in the house. Still don't hit the garbage/recycle pile unless they're dead though. Or have a horrible CRI.
On that note, does anyone have recommendations re 6500k (or thereabouts) color temp high CRI bulbs of any tech that are dimmable? As well as any being available in different single outputs?
I calibrate displays/home theaters and a touch of backlighting/ambient light does wonders for increasing picture quality, as well as making the viewing experience much more enjoyable for my customers who insist on watching in total darkness save for the output from the display. It's amazing how fatiguing and sometimes even painful, it can be to watch in total darkness.
The problem is that most folks are a tough sell on the ~$300 display calibration & don't want to drop ~$75-100 on a basic light that meets the CIE D65 white point with a 90+ CRI. Decent products can double or triple that cost.
There are a ton a products sold as "bias lighting" on eBay/Amazon/etc that don't give specs, but the sellers are smart enough to give the desired specs when asked. Basically, can't trust em as far as I can throw em.
Steve
Sent from my SM-G900V using Tapatalk
