I have been using one for quite a few months now. They are good for the money.
As for accuracy, it is very good compared to the Fluke current clamps in the closed mode (at least partially because the hole is much smaller).
Probing current through a PCB track is a little fiddly, as it has to be held upright from the board and centered over the track. As is normal with these, you also have to adjust it for the width of track you are measuring. Without taking too much care, my measurements have normally come out within 10% of a measured reading, and taking a bit of time, better than that, down to 5% or so.
I use it a lot for working out where shorts are in boards, and with 5MHz bandwidth, it is sometimes possible to see pulsed currents being drawn in operation
