Author Topic: coolest looking components  (Read 25417 times)
Offline sarepairman2Topic starter
« on: February 22, 2016, 06:38:11 pm »
ferrite beads.
Offline alsetalokin4017
Re: coolest looking components
« Reply #1 on: February 22, 2016, 06:55:55 pm »
Mercury rectifier.
Offline T3sl4co1l
    • Seven Transistor Labs
« Reply #2 on: February 22, 2016, 07:16:08 pm »
Those old British film capacitors with the dipped color codes/bands.
Lots of vacuum tubes (see above).  RK707 is a neat one:
Seven Transistor Labs, LLC
Offline veedub565
« Reply #3 on: February 22, 2016, 07:45:24 pm »
Nixie Tubes
Offline German_EE
« Reply #4 on: February 22, 2016, 09:13:31 pm »
Warren Buffett
Offline Stanley Linus
« Reply #5 on: February 22, 2016, 09:44:59 pm »
Tubes.
« Reply #6 on: February 22, 2016, 09:54:40 pm »
:palm:
Offline Alexei.Polkhanov
« Reply #7 on: February 22, 2016, 10:01:40 pm »
Old Soviet RAM ICs.
Offline crispy_tofu
« Reply #8 on: February 22, 2016, 11:25:08 pm »
Offline tggzzz
« Reply #9 on: February 22, 2016, 11:28:27 pm »
Late 70s Burr Brown thick film hybrids were sufficiently pretty they made a calendar out of them. Pirelli for geeks :)
https://entertaininghacks.wordpress.com/2015/07/07/images-of-late-70s-burr-brown-thick-film-hybrid-ics/
Offline cdev
« Reply #10 on: February 23, 2016, 12:22:45 am »
Old core memory, which reminds me of - weaving or macrame.. people collect it now..
http://www.cs.ubc.ca/~hilpert/e/coremem/
https://www.flickr.com/photos/jurvetson/8007180700
Offline AlxDroidDev
  • Country: br
    • Arduino Web Brasil
« Reply #11 on: February 23, 2016, 12:39:40 am »
Those "Radiation tolerant" ICs are usually quite good (and odd) looking:
and
"The nice thing about standards is that you have so many to choose from." (Andrew S. Tanenbaum)
Offline brillopad
« Reply #12 on: February 23, 2016, 12:51:54 am »
Nixie Tubes
STC used to make those in Devon in the UK (Torbay) - I built the test gear for them in @ 1967.
« Reply #13 on: February 23, 2016, 01:20:31 am »
Liquorice Allsort polyester capacitors. I used to have loads of these, made by Mullard (later Philips).
Offline Halcyon
  • Global Moderator
« Reply #14 on: February 23, 2016, 05:29:28 am »
I can't believe no one has posted the most obvious...
Offline rich
« Reply #15 on: February 23, 2016, 05:48:18 am »
Depends on the judging criteria - Cool component, yes. Coolest looking component, no.
Offline Armxnian
  • Computer Engineering Student
« Reply #16 on: February 23, 2016, 07:09:21 am »
Silicon wafer
Offline Rerouter
« Reply #17 on: February 23, 2016, 07:40:11 am »
Microscopic led's, both visual, and convert surrounding heat into light, cooling down the surroundings :)
Offline ivaylo
« Reply #18 on: February 23, 2016, 07:42:49 am »
This is easy... They are all beautiful, this is why we are here. You dont have to go fancy:
Or anything high voltage or high frequency:
Offline nali
« Reply #19 on: February 23, 2016, 07:58:53 am »
Offline JoeN
  • We Buy Trannies By The Truckload
« Reply #20 on: February 23, 2016, 08:07:08 am »
This is technically a vacuum tube, for a cyclotron.  Does it count?   >:D
Have You Been Triggered Today?
Offline JoeN
« Reply #21 on: February 23, 2016, 08:15:08 am »
Offline JoeN
« Reply #22 on: February 23, 2016, 08:16:44 am »
These aren't particular outstanding components, I just like the way the guy did the images.
Offline tggzzz
« Reply #23 on: February 23, 2016, 10:06:20 am »
Forgot to add one picture, which seems de rigueur here :) More calendar pics at https://entertaininghacks.wordpress.com/2015/07/07/images-of-late-70s-burr-brown-thick-film-hybrid-ics/
« Reply #24 on: February 23, 2016, 06:32:50 pm »
Porn
