Author Topic: PCB connector, right angle  (Read 465 times)
Offline PlainNameTopic starter
  • Country: va
« on: August 07, 2021, 08:36:48 pm »
I am stuck for an easily acquired connector pair for attaching one PCB to another at right angles. My particular requirements are that the horizontal PCB may have PTH connector, and will meet the vertical PCB edge-on (forming the base part of a T junction). The vertical PCB must have a SMD connector - no pins poking out the other side of the PCB.
I would like two sets of 4 pins, preferably in two rows, but single rows or a single connector of 2x4 would be acceptable as second best.
So far I can find a Samtec jobby for the horizontal part:
https://uk.rs-online.com/web/p/pcb-headers/7656423/
but that bit is ten a penny if I go PTH. It's the other bit that has me stumped: straight 2x4 SMD socket should be easy to find, but I'm blowed if I can.
Any suggestions? The project is a front panel attached to a gizmo PCB, hence the requirement for SMD on the back side. Needs to be cheap, not take up much room, and the vertical PCB must be adjustable for position (at the design stage, to account for the main PCB mounting height in the box).
Online jc101
Re: PCB connector, right angle
« Reply #1 on: August 08, 2021, 08:39:41 am »
If you're in the UK, drop a line to Toby ( https://www.toby.co.uk ) and explain what you are looking to achieve.  They sell via their website but I've found them good at hunting down such things too once they understand the requirement.
The following users thanked this post: PlainName
  • Country: va
« Reply #2 on: August 08, 2021, 08:54:56 am »
Thanks! I see they do light pipes too, which is another thing on my list :)
Offline fcb
    • Electron Plus
« Reply #3 on: August 08, 2021, 10:01:14 am »
+1 for Toby.  Also, Samtec are very responsive (Toby are also agents for Samtec).
