Author Topic: Is this a scam site?  (Read 646 times)
Offline PlainNameTopic starter
  • Country: va
« on: June 12, 2024, 08:16:30 am »
Or a web dev filling blank space with AI?
https://www.alliedcomponents.com
Looks pukka initially but dig down and...
The maximum voltage across a resistor is the amount of voltage it can safely withstand without damage. The maximum voltage rating of a resistor is determined by its power rating and the ambient temperature of the environment in which it operates. Generally, the maximum working voltage is 1.5 times the resistor’s power rating. For example, if a resistor has a power rating of 2 watts, the maximum working voltage should be 3 volts. It is also important to note that the maximum working voltage of a resistor is not the same as its breakdown voltage. The breakdown voltage is the voltage at which the resistor fails due to excessive current flow. The maximum working voltage is the voltage at which the resistor can safely operate without damage.
Offline Psi
Re: Is this a scam site?
« Reply #1 on: June 12, 2024, 08:23:14 am »
That is 100% AI created text.
Offline ArdWar
  • Country: sc
« Reply #2 on: June 12, 2024, 08:47:11 am »
Looks like your standard US front company for East Asian manufacturers. Nothing particularly unusual tbf. Blog posts about a too basic stuffs are just extra fluff there and you can practically ignore them. It's part of their SEO or something.
  • Country: va
« Reply #3 on: June 12, 2024, 12:29:17 pm »
Clearly :)
Oh, haven't stumbled across one before, that I'm aware of. Maybe Farington knows about them!  >:D
Even so, you'd think a human eye would pass over them before they illustrate to world+dog that they know nothing about their business.
Online wraper
  • Country: lv
Offline MT
  • Country: aq
« Reply #5 on: June 12, 2024, 12:57:49 pm »
https://www.google.com/maps/@33.6757772,-117.6537679,3a,75y,255.34h,94.34t/data=!3m6!1e1!3m4!1sWFnk0UNDQDLTddF4QFgxog!2e0!7i16384!8i8192?coh=205409&entry=ttu
  • Country: va
  • Country: va
« Reply #7 on: June 12, 2024, 06:03:03 pm »
Beats me how they can let their website host such blatant cobblers.
Online wraper
  • Country: lv
« Reply #8 on: June 12, 2024, 08:06:32 pm »
  • Country: va
« Reply #9 on: June 12, 2024, 10:06:06 pm »
https://www.digikey.com/en/supplier-centers/allied-components-international
Gives me a 404.
Either was a temporary glitch on digikey side or something wrong on your side. Works fine for me.
Works now but only if I use the US site. Earlier, when I use the UK site it couldn't find them in its list of suppliers, so perhaps it's a country thing.
Edit: went to get a listing of the suppliers from each site, and now that link gives a 404, presumably because I have the UK site open in another tab. Nevertheless I took a screeny of the appropriate part of their A-Z.
« Last Edit: June 12, 2024, 10:09:16 pm by PlainName »
