Remove unnecessary items and dispose of them properly
Make work easier by eliminating obstacles.
Reduce chance of being disturbed with unnecessary items
Prevent accumulation of unnecessary items
Evaluate necessary items with regard to cost or other factors
Remove all parts not in use
Segregate unwanted material from the workplace
Need fully skilled supervisor for checking on regular basis (ie significant other)
Don't put unnecessary items at the workplace & define a red-tagged area to keep those unnecessary items
Arrange all necessary items so they can be easily selected for use
Make it easy to find and pick up necessary items
Ensure first-come-first-served basis
Make workflow smooth and easy
All above work should be done on regular basis
Clean your workplace completely
Use cleaning as inspection
Prevent machinery and equipment deterioration
Keep workplace safe and easy to work
Keep work place clean
Standardize the best practices in the work area.
Everything in its right place.
Every process has a standard.
Perform regular audits
Anything left out? Now I will see if I can do one of them
