Dear Mightyohm:
--With regard to the recommendations by Mechatrommer, let me say that I completely agree with the part about mechanical repair of the ZIF socket. I hope it turns out this is the problem. However with regard to Mechatrommer's statement that:
"unless there's visible significant amount of rust, maybe the problem is not the "cleaning solution at all".
1) Ferrous materials are almost never used on the surfaces of soldered components, because plain old iron just does not solder very well. Indeed that is why one almost never sees ferrous oxide in soldered connections. In most cases where mechanical insertion is involved, any corrosion or dirt can be difficult or impossible to see
2)I said:
"My advice was strictly confined to the problem of oxidation. If the problem is mechanical in nature then obviously a new socket would be the thing to try.".
--I do not think I, or anyone else said that oxidation "IS" the problem.
3)The reference to the "real problem" make it sound like someone has been misleading you.
Reflow appliances that heat all the solder connections on the board at once are problematic for obvious reasons. Hot air may work, especially if you block off of the rest of the board with aluminum foil. If the back side of the ZIF socket is blocked by the body of the socket a solder sucker may not work. It would be kind of like trying to use your mouth to get beer out of a standing beer bottle. Likewise turning the board upside down and using a solder sucker (which is awkward and difficult) may not work either due to capillary action. I have done this very thing many times and it "taint easy McGee".
--With regard to the recommendations by nukie. I completely agree with his recommendation to obtain a high quality socket, gold plated if possible. I also agree that a Dremel tool could be used to chop up the socket, to make desoldering easier, but do not let your hand slip.
--Nukie's statement that:
"Detoxit and the likes is only a temporary fix."
--Is far from being completely correct. Sometimes it turns out that the DeoxIT procedure I outlined will not be a permanent fix, certainly, but only because of other underlying problems not related to the treatment, like corrosion underneath the plating and so forth. As I already stated the treatment will not solve mechanical problems, only problems of dirt and corrosion. I do not think I could in good conscience recommend blanket replacement and re-soldering of all components in all cases where intermittent open is the problem. In some cases the problem is merely dirt and or corrosion, plain and simple. DeoxIT products are used successfully by thousands of professional every day for repair and prophylaxis, and they not at all like nostrums being pushed by snake oil hucksters on the shopping channel.
--And, finally to the problem at hand. If you are sure your only choice is to desolder the socket, I have one recommendation in addition to the ones already stated by others. That is ChipQuick. Mount the board upside down in or on a vise so that you can reach the bottom and the top. Pull down on the socket while keeping the ChipQuick liquid and it should slip out easily. You can get ChipQuick at Digikey for $13.50 (which is enough to do several projects), at the Web page listed below:
http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=SMD1-ND--Also please see below a video of ChipQuick being used to remove an SMD component with 40 odd pins:
Chip Quick Review Easy IC Chip Removal W/ Flux - Video--Sorry to be so long winded, but I felt it necessary to correct some misapprehensions and erroneous assertions. Best Regards
Clear Ether
