Author Topic: LCD replacement on a Fluke 8024B  (Read 911 times)
Offline zmetzingTopic starter
« on: August 26, 2021, 10:34:17 pm »
Just repaired a Fluke 8024B that was found in the e-waste bin. The LCD was replaced, like others in this thread, and two electrolytic capacitors were also changed out as they had started to leak. Mouser had the LCD (LCD-S3X1C50TR/A). I'm thinking of adding LEDs in the case for the missing UP/DOWN signal indicators on the original glass.
Kudos to the threads on this forum about the possibility of replacement.
« Last Edit: August 26, 2021, 10:41:56 pm by zmetzing »
Offline lowimpedance
  • Watts in an ohm?
Re: LCD replacement on a Fluke 8024B
« Reply #1 on: August 27, 2021, 01:44:11 am »
Nice, another classic saved :-+.
