Greetings EEVBees:
--Well, there has been a little progress, or regress, depending on how you look at it on this Vizio M320SL 32" LED TV repair. Tom66 pointed out that the ARM Chip, marked MEDIATEK ARM, MT5396CFJ, 1203-BTAH, ETNAY642, was likely to eventually fail permanently, and I thought that Tom was probably correct. So this is what I have done so far. I managed to obtain from ShopJimmy a repair kit consisting of all boards, and all cables, with a 180 day guarantee, for $92.05 US. See the attached sticker, which must have come from a new or low mileage unit with a broken screen or a similar situation.
--From looking on eBay, I found that the Main Board alone was going for about the same money, so I judged it to be a resonable investment, as I plan to buy another of these if possible. See the attached picture for the price of the three larger boards alone for $230 plus shipping.
--So it was working with the fan, but I would have had to cut a hole in the back, and even then it was unlikely to last. So, into the breech I stepped. I decided to remove the heat sink, identify the chip, remove the thermal compound, and replace it with Arctic MX-4, recommended here as the best. I tried gingerly to remove the heatsink by prying and twisting but no go. I then tried heat and managed to get it to release at about 100C. As you can see by the attached pictures, Vizio used a quicky rubber pad which had a very poor thermal connection to the chip and the heatsink. Also the heat sink was held down by loose plastic clips instead of screws. In any case, I applied the MX-4 and re-installed. The TV at first was showing the dreaded stripe pattern and now will not turn on at all, by any means. So now I have in mind to check the standby voltage, and all of the PS voltages and all voltage regulators. Any pointers would be appreciated. Once I have a better idea of what is wrong, I will proceed to try any necessary repairs, in order to get back to just the stripe problem.
--I know it seems that I am going the long way around the barn but I, am trying to learn something, just as much as I am, just trying to solve the problem at hand. So, once I am pretty sure I have the problem confined to the Main Board, I will try, blowing high pressure air under the ARM Chip on the theory that it might remove any of the Unleaded Solder Tin Whiskers, just for fun. I then will try to do a reball of the original chip, protecting the rest of the board with aluminum foil. I already have a heat gun, a Hakko 851 Rework Station (see picture), and a toaster oven for preheating, but I am thinking of getting one of the larger plate warmers and trying it. I still need to get a couple of items before proceeding, including, hopefully a wider and slightly taller heatsink, and figuring out how to screw it down, if possible, without creating a short. This is a long term project, and I will report back from time to time, as it progresses.
Any and all advice would be sincerely appreciated. I noticed that several of the screws holding the Main Board to the chassis were rather loose, and I was wondering if that could have contributed to the overheating ARM. And, does anyone know where to get a new MEDIATEK ARM, MT5396CFJ, 1203-BTAH, ETNAY642 Chip?
--If all else fails, hopefully I will be able to just install the new boards, and Bobs your uncle.
"If it weren't for Philo T. Farnsworth, inventor of television, we'd still be eating frozen radio dinners."
Johnny Carson 1925 - 1992
Best Regards
Clear Ether
