My car battery charger is an old unit, made by GE circa 1950, and it does the job, though i did upgrade it a bit over the years. The boost charger is by using the arc welder, as I added a half wave rectifier diode, a press stud diode I had around on an aluminium plate, a 40A thermal breaker and a charge socket for a wire. Will give enough charge into a flat battery to start in the time it takes the thermal breaker to heat up to trip point, and then a few reset cycles and it will be enough in most cases. Works on 12 and 24V systems, you just have to set the arc current shunt to change the voltage and current by shunting the magnetic field in the secondary. Kills SLA batteries though, current is a little high for them.
