Author Topic: Gallium Wetting  (Read 5200 times)
Offline dexters_labTopic starter
Gallium Wetting
« on: February 19, 2015, 02:39:08 pm »
long shot this i know... but
I'm trying to find a material to store some gallium in, gallium seems to be very 'wet' as in it leaves particles behind on lots of things when it's liquid including the plastic container i have some stored in now and it seems to just want to spread itself about!
was wondering if there is some plastic that it doesn't wet to?
Offline ElektroQuark
    • ElektroQuark
Re: Gallium Wetting
« Reply #1 on: February 19, 2015, 02:41:15 pm »
Did you tried PTFE?
« Last Edit: February 19, 2015, 04:08:56 pm by EdoNork »
Offline Mechanical Menace
Re: Gallium Wetting
« Reply #2 on: February 19, 2015, 02:46:45 pm »
Have you tried coating the container by rubbing some of the gallium into it? I know that works with glass and quartz, maybe it will with some plastic?
Second sexiest ugly bloke on the forum.
"Don't believe every quote you read on the internet, because I totally didn't say that."
~Albert Einstein
Re: Gallium Wetting
« Reply #3 on: February 19, 2015, 03:06:13 pm »
not tried anything yet, was waiting for suggestions, i didn't want to make a mess with it trying!!  :scared:
Re: Gallium Wetting
« Reply #4 on: February 19, 2015, 03:13:30 pm »
It's almost impossible not to make a mess while playing with gallium. If you get it on your bare hands it goes everywhere you touch, the smallest amount spreads far too and is a right bugger to clean up lol.
I'm sure you already know this but be very careful with it around other metals...
EDIT:
Oh and don't trust the claims that it's non toxic. It is at least mildly toxic* and unlike mercury also wets skin so it's easier to be poisoned by it through just handling instead of by ingesting or inhaling it.
« Last Edit: February 19, 2015, 03:33:01 pm by Mechanical Menace »
~Albert Einstein
Re: Gallium Wetting
« Reply #5 on: February 19, 2015, 04:02:05 pm »
I would guess you will not get wetting with a PET plastic bottle, and you will definitely not get wetting with either PTFE or a wax lined bottle ( it will hold HF acid no problem, though the glass lid will dissolve). Wax though will need to be kept in a fridge, and this will also solidify the Gallium as well so it is less likely to wet.
Re: Gallium Wetting
« Reply #6 on: February 19, 2015, 06:00:42 pm »
thanks for the suggestions guys
yea i am aware of gallium's effects on other (most!) metals, i will be experimenting!  >:D
Offline jwm_
    • Not A Number
Re: Gallium Wetting
« Reply #7 on: February 20, 2015, 12:54:10 am »
gallium wets everything it seems. there are some ideas on this thread on how to do it, but I have not tried any. I do have a high vacuum chamber so may try sputtering it onto glass, seems like something Ben Krasnow would have already experimented with.
http://scitoys.com/board/messages/1/202.html?1263264803
