Author Topic: Can we have an Omega smiley?  (Read 21201 times)
Offline apellyTopic starter
  • Probe
« on: August 25, 2016, 08:55:25 pm »
At risk of being "one of those guys"; it looks to me like smileys in the forum are a little icon in some folder with some associated free text. When rendering, the icon is substituted for the text.
If I'm right, a simple smiley that inserts \$\Omega\$ would serve two functions, and be easy to implement. Primarily it'd prompt people to remember that slash dollar are the escape characters to initiate \$\LaTeX\$, but it's also a handy short cut.
Online EEVblog
Re: Can we have an Omega smiley?
« Reply #1 on: August 27, 2016, 03:15:22 am »
At first this didn't make sense, having symbols for emoticons, but now I get that it could be useful.
If someone has a list of useful symbols in the appropriate size then I can add them.
Omega would be :ohms:
  • Probe
« Reply #2 on: August 27, 2016, 03:35:10 am »
I was actually thinking of functionality similar to the url button; it inserts text that you can then edit as desired. It saves a bit of typing, but more importantly it shows the syntax if you've forgotten it. In my imagination an ohms button would literally insert the characters "\$\Omega\$"
I referred to smileys, because they appear to be a shortcut to insert some text and are apparently not too hard to create.
I would use latex a lot more if I didn't have to re-research how to use it every time.
Anyway, I also see no reason to have a static gif shaped like omega. It's only useful if it fits in with the text.
« Reply #3 on: August 27, 2016, 04:05:28 am »
Do the Alt codes work in the forum software, I think I'tried them before and they wouldn't.
http://usefulshortcuts.com/alt-codes/greek-alt-codes.php
Let's try Ohms: Alt234
Nah  :(
Online EEVblog
« Reply #4 on: August 27, 2016, 04:26:13 am »
Testing:
\$\Omega\$
\$\omega\$
\$\Delta\$
« Reply #5 on: August 27, 2016, 04:27:47 am »
Another try from this list
http://www.planetquark.com/images/library/tips/Special_CharacterShortcuts_v.1.2.pdf
WINDOWS|To access the desired glyph, first turn on NUM LOCK. Then hold down the ALT key while using the numeric keypad to enter the the four-digit number shown.
Release the NUM LOCK key when finished. So, to access the n with a tilde accent, press NUM LOCK, then hold ALT
and key 0241. Hit the NUM LOCK key again to release it.
P15
or
&Omega
Nah, needs someone smarter than me.  :palm:
Offline rdl
« Reply #6 on: August 27, 2016, 04:55:04 am »
© ? µ £
I don't have any numeric keys on this keyboard, but copy and paste seems to work. I wonder if it has any browser or OS dependencies though. Does everybody else see the 4 symbols above?
Okay, they all worked in preview, but after posting the "omega" is a question mark. Which is weird.
« Last Edit: August 27, 2016, 05:26:36 am by rdl »
  • Probe
« Reply #7 on: August 27, 2016, 05:02:13 am »
Testing:
\$\Omega\$
\$\omega\$
\$\Delta\$
Nice, isn't it?
Two great resources:
http://meta.math.stackexchange.com/questions/5020/mathjax-basic-tutorial-and-quick-reference
http://detexify.kirelabs.org/classify.html
The second one lets you draw that character you want, then gives you its name.
Offline Brumby
« Reply #8 on: August 27, 2016, 05:06:18 am »
Not really.  Posting will go through a bit more processing than Preview.  Obviously, there is something special happening when you 'Post'.
Offline Brumby
« Reply #9 on: August 27, 2016, 05:10:58 am »
Testing:
\$\Omega\$
\$\omega\$
\$\Delta\$
Cute
\$\Omega\$  gives you:  \$\Omega\$
\$\omega\$  gives you:  \$\omega\$
\$\Delta\$  gives you:  \$\Delta\$
Offline rdl
« Reply #10 on: August 27, 2016, 05:14:53 am »
I see the same thing before and after "gives you:"
backslash dollar sign backslash Omega backslash dollar sign
Offline Brumby
« Reply #11 on: August 27, 2016, 05:17:21 am »
Does Dave's test show up ok?
Offline Brumby
« Reply #12 on: August 27, 2016, 05:19:04 am »
Is this any different?
\$\Omega\$
  gives you:
  \$\Omega\$
\$\omega\$
  gives you:
  \$\omega\$
\$\Delta\$
  gives you:
  \$\Delta\$
Offline rdl
« Reply #13 on: August 27, 2016, 05:21:03 am »
Nope, looks the same. Dave's does too.
Offline Brumby
« Reply #14 on: August 27, 2016, 05:36:49 am »
Then it's going to be something to do with your particular environment.
I'm not familiar with the in's and out's - but there will be someone here that will know.
Offline rdl
« Reply #15 on: August 27, 2016, 05:47:03 am »
It was. I had to enable javascript from some place called mathjax.org
I don't remember seeing that here before, only eevblog.com and supplyframe.com
Offline Brumby
« Reply #16 on: August 27, 2016, 06:21:26 am »
Thought it might be something like that - but I didn't really know.
Offline ez24
  • L.D.A.
« Reply #17 on: August 27, 2016, 06:30:20 am »
\$\Omega\$  :)   = Omega smiley
So to answer your question - Yes
What is interesting is that there is a time delay - I think it has something to do with the Australian Post Office
« Last Edit: August 27, 2016, 06:32:43 am by ez24 »
Offline Brumby
« Reply #18 on: August 27, 2016, 07:03:06 am »
I doubt it.
If it was, there would be a fee or charge of some sort...
Online EEVblog
« Reply #19 on: August 27, 2016, 07:06:33 am »
To add these I will need gif image files of the actual symbols in the appropriate size. I can't seem to find a handy list, even after downloading the entire build and looking at the image file directories  :-//
Offline Brumby
« Reply #20 on: August 27, 2016, 07:14:39 am »
What pixel size are you looking for?
Online IanB
« Reply #21 on: August 27, 2016, 07:23:53 am »
Seemingly it needs to be about 12 pixels high. Here's a test example (attached) of the ohms symbol. It's not the right quality, but it could be used to test the concept.
Something like this, I guess:
    R = 30
« Last Edit: August 27, 2016, 07:29:36 am by IanB »
Offline Brumby
« Reply #22 on: August 27, 2016, 07:29:45 am »
Test:
\$\alpha\$    alpha     \$\Alpha\$    Alpha
\$\beta\$    beta     \$\Beta\$    Beta
\$\gamma\$    gamma     \$\Gamma\$    Gamma
\$\delta\$    delta     \$\Delta\$    Delta
\$\epsilon\$    epsilon     \$\Epsilon\$    Epsilon
\$\zeta\$    zeta     \$\Zeta\$    Zeta
\$\eta\$    eta     \$\Eta\$    Eta
\$\theta\$   theta     \$\Theta\$    Theta
\$\iota\$    iota     \$\Iota\$    Iota
\$\kappa\$    kappa     \$\Kappa\$    Kappa
\$\lambda\$    lambda     \$\Lambda\$    Lambda
\$\mu\$    mu     \$\Mu\$    Mu
\$\nu\$    nu     \$\Nu\$    Nu
\$\xi\$    xi     \$\Xi\$    Xi
\$\omicron\$    omicron     \$\Omicron\$    Omicron
\$\pi\$    pi     \$\Pi\$    Pi
\$\rho\$    rho     \$\Rho\$    Rho
\$\sigma\$    sigma     \$\Sigma\$    Sigma
\$\tau\$    tau     \$\Tau\$    Tau
\$\upsilon\$    upsilon     \$\Upsilon\$    Upsilon
\$\phi\$    phi     \$\Phi\$    Phi
\$\chi\$    chi     \$\Chi\$    Chi
\$\psi\$    psi     \$\Psi\$    Psi
\$\omega\$    omega     \$\Omega\$    Omega
Interesting, some capitals are not interpreted...
« Last Edit: August 28, 2016, 11:04:24 am by Brumby »
Online IanB
« Reply #23 on: August 27, 2016, 07:33:42 am »
Test:
\$\alpha\$ alpha     \$\text{A}\$ Alpha
\$\beta\$ beta     \$\text{B}\$ Beta
\$\epsilon\$ epsilon     \$\text{E}\$ Epsilon
\$\zeta\$ zeta     \$\text{Z}\$ Zeta
\$\eta\$ eta     \$\text{H}\$ Eta
\$\iota\$ iota     \$\text{I}\$ Iota
\$\kappa\$ kappa     \$\text{K}\$ Kappa
\$\mu\$ mu     \$\text{M}\$ Mu
\$\nu\$ nu     \$\text{N}\$ Nu
\$\omicron\$ omicron     \$\text{O}\$ Omicron
\$\rho\$ rho     \$\text{P}\$ Rho
\$\tau\$ tau     \$\text{T}\$ Tau
\$\chi\$ chi     \$\text{X}\$ Chi
They are the same as the Roman letter, they do not need special handling...
« Last Edit: August 27, 2016, 07:42:57 am by IanB »
Offline Brumby
« Reply #24 on: August 27, 2016, 07:45:28 am »
Yeah ... but it spoils the logic.
