"They" seems like a bit of a generic point.
The reason some companies might be doing away with Gigabit ethernet is that Gigabit 802.11AC has taken the spot and there is no need for it. I am sure there will be laptops with an Ethernet port, but it's not really needed that much anymore.
The reason isnt because of wifi AC, its because people rarely use ethernet. However even in the face of 4x4 wifi ac gigabit ethernet is still superior because of less interference and better consistent performance. Very easily i fill up a full gigabit ethernet port transferring to my file server which has SFP+. windows says 99% NIC use but the cool thing i can do with ethernet that you cant do with wifi is that i can upload at link speeds to my file server and at the same time get all the stats and info from my file server (like task manager, remote desktop) and also watch a video at the same time while uploading thanks to the full duplex nature of gigabit ethernet. wifi is only half duplex, try this on wifi and you will run into issues, packet drops and other problems.
802.11 AC is on the 5 Ghz band which has WAY more channels than 2.4 and has less interference due to the fact that few devices use 5Ghz RF. But your points still stand.
Say all you like about wifi but wifi will never be a substitute for gigabit ethernet or even SFP+. Those gigabits worth of bandwidth and full duplex is better than wifi half duplex. Sure 5Ghz has more channels and less interference but i've seen many devices on auto act weird like shadowing the channel my AP uses even though there are many other channels free. If you were in the UK and you checked your wifi at home the number of 5Ghz is already huge. Every ISP here gives out a crappy wifi AC router and the general design of consumer wifi isnt great.
But lets compare proper things. I tested the capability of wifi AC and it is far from ethernet. In my test i used intel 2x2 adapter with an asus AC68U and a server on gigabit ethernet not using realtek. I crammed as many packets as the CPU would allow and the maximum i got was 90% link utilisation with many dropped packets. If this were gigabit ethernet i could do the same with no dropped packets and stream a 4k movie at source at the same time while spamming the bandwidth tester as much as the CPU allows. This is where ethernet differs from wifi. Sure wifi AC shows impressive numbers but i had to be within a few meters of the AP for that 5Ghz and gigabit ethernet has a range spec of 100meters using cat5e which even with 4x4 wifi you will not get at that range. So despite how awesome they market wifi to be wifi is a convenience not something that will ever be able to replace the performance and reliability ethernet or wire. Practical wifi rates for wireless AC is 60% of the link rate so if you wish to use that fancy 4x4 wifi AC bandwidth you would be tethered to within a few meters of the AP and thats if it is a good one on a good day whereas for gigabit ethernet as long as the system isnt fully utilised in resource getting 99% of the link utilised is no problem whatsoever and the full duplex nature allows you to do even more without running into collisions and inconsistent performance.
Your telling me. I've never used 802.11AC. I am stuck with 2.4Ghz 802.11N until I can manage a more impressive AP. NOBODY uses the 5Ghz band here. MAYBE some wireless home phones, but you can't hold 2.4 Ghz anything here. I have a 2.4 Ghz headset, three 2.4Ghz access points, all our phone handsets use 2.4 Ghz comms, along with bluetooth devices one or two, and probably more stuff I forgot. Even with a 150 - 300 Mbps link speed on a router with nothing else on it on a direct ethernet link to a 90/90 internet link, a speed test gives a third of the speed. About 35/45 or so, I forgot by now. But that is from a network speed of 300 Mbps to 30-40 in lost packets alone. I mean I could do better with sneakernet. In my situation, and the situation along most of the US, a 5Ghz link would drop very little even with it's reduced range.
Either way you are right, and I am not claiming ethernet should be replaced. I was just giving my two cents on why it might be. Thing is while a few laptops might be removing this, I don't see it happening in the future. Anyways with USB 3/3.1 speeds you could also put a fast NIC on a USB port.
Either way, AC is pretty cool, though I have never tried it.
