Quote from: onesixright on January 15, 2017, 08:06:52 pmAwesome, thanks! Any idea how you create the "golden fingers" in kicad? (its just a footprint )I saw a few of these "edge connectors" on aliexpress and ebay. But all they mention is the pitch. To create your own you need a bit more i assume? Any idea if these are standard sizes ?Common edge card connectors are PCI/AGP/PCIe x1~x16/miniPCI/miniPCIe/m2, these due to being highly used in computer industry, are very cheap.Unless you have a lot of money that can justify designing another connector format, I would suggest using a PC standard edge connector for lowest R&D cost.
Edge connector fingers should be plated with hard gold. This may involve an additional charge from the PCB fab as this is an extra step.ENIG is not thick or hard enough for edge connectors.
