i have those "BONENS" brand bought in lot from ebay. 1Kohm 10 turns used for ±2.3V divider for voltage offset, hardly move from and accurate for ±1mV range worst case after few minutes (i cant see any visible movement even at ±500uV range), like 30 minutes or so, even with moderate wind or mouth blow, on naked pcb. did some slight pcb banging on the desk made little to no change. so its 0.04348% deviation or error worst case, for my 1Kohm its around ±0.2ohm tolerance, for your 100Kohm it should be ±20ohm, fair as you reported, but it works to my circuit spec, ie acceptable.
blowing the Bonens trimpot with 100degC hot air, sure the voltage offset moved further down, but blowing the zeners that form the voltage range for it, moved the offset up, so i accidentally accomplished the "tempco cancellation" engineering achievement on my circuit, no worries
the trimpot that i observed has taken significant abuses from me, ie few times solder desolder, all leads decapitated. burn marks due to soldering iron accidentally hit it from the side.
i agree, teardown comparison side by side will be a good idea, lets see what they are made of. i dont have original Bourns to compare with. and you havent explain your measurement setup, what meter did you use?
