Author Topic: German technical term on part  (Read 1395 times)
Offline AlexTopic starter
« on: January 29, 2018, 06:18:31 pm »
I am hoping a German speaker can help me understand what is written on this label.
The label was on a turbomolecular pump, if that helps. The first word is 'complete' the second one no idea.
Unfortunately the writing is not very clear.
Alex
« Last Edit: January 29, 2018, 06:20:50 pm by Alex »
Offline taydin
  • Country: tr
Re: German technical term on part
« Reply #1 on: January 29, 2018, 06:21:00 pm »
it says "complete overhaul" (komplett überholung)
« Last Edit: January 29, 2018, 06:23:05 pm by taydin »
Real programmers use machine code!
My hobby projects http://mekatronik.org/forum
« Reply #2 on: January 29, 2018, 06:33:25 pm »
Many thanks taydin. Cryptic message, I wonder if the label was placed there before or after the overhaul :-)
Alex
Offline capt bullshot
« Reply #3 on: January 29, 2018, 07:27:17 pm »
Yes, that's correct, but I was confused by the handwriting, at first glance I've read "Komplettüberladung" which would mean "total overcharge", which I would have interpreted as "this turbo pump was overloaded and borked".
BTW
Did one ever see such a turbomolecular pump explode? There's quite a bit of energy stored when running at nominal speed. Test chambers usually are buried underground or have wooden planks at all walls to absorb the shrapnel.
Offline Twoflower
« Reply #4 on: January 29, 2018, 07:34:04 pm »
I would say the label indicates the need of the full overhaul. Otherwise I would write 'Komplettüberholt' as it has been done. But that's a guess.
Offline The Soulman
  • The sky is the limit!
« Reply #5 on: January 29, 2018, 08:05:24 pm »
Yeah, I read it more as a verdict than something that is finished. Could be wrong tho, I'm no German.  :-X
« Reply #6 on: January 29, 2018, 08:21:27 pm »
I agree with "Zweiblum" :)
"Komplettüberholung" is a noun and imo in this context it is an instruction command of what has to be done with this thing.
"komplett überholt" means imo in this context: the complete overhaul has been done. If it was successfull is another story.  ;)
But the word on the sticker reads clearly as "Komplettüberholung". So, likely, this turbomolecular pump is waiting for it's complete overhaul.
HTH
Andreas
