My dad just got himself a new laptop and it had win 10 on it.
Took about 30 minutes to boot the laptop to the desktop. ![Confused :-//](https://www.eevblog.com/forum/Smileys/default/confused0024.gif)
In 30 min i can put a full install of Win7, god dammit.
Bastard OS loads the CPU, bashes the HDD at 100% and eats 2gigs of RAM while it's at it on idle. ![Rant :rant:](https://www.eevblog.com/forum/Smileys/default/rant.gif)
I don't know a thing about Win10 but i don't think this is normal, this chewing 50% of RAM on idle thing.
Also when viewing YT video full screen the damn taskbar doesn't go away.
If Win10 was made to piss people off then Microsoft did a damn good job at it. ![Clapping :clap:](https://www.eevblog.com/forum/Smileys/default/clap.gif)
#1 Yes, Windows 10 is utter trash (I am on it now, and was an "Insider" - I tried most of the Betas) -
#2 I would "UPGRADE" that machine to Windows 7 ASAP!
>>> ONCE YOU HAVE INSTALLED WINDOWS 7, INSTALL "Never10" https://www.grc.com/never10.htm DO NOT SKIP! <<<
#3 You *NEED* to put an SSD in that machine, no ifs or buts, to NOT do so is inexcusable in 2017 - rotary spinning discs are the dark ages!
#3a - You need AT LEAST 8GB of RAM - if it doesn't have at least that, what on EARTH machine is that?!
#4 You neglected to mention the make/model of the machine; it could be a consumer-targeted device pre-bogged-down with a BOAT LOAD of junkware and "trials", "utilities" etc.
#5 The copy of Windows 10 on that machine WILL be activated and linked to the unique machine ID and tied to his Microsoft account (the official term from MS is a "digital entitlement" for Windows 10), so if he DOES stay with Windows 10 (his choice, clearly), it will auto-activate ANY TIME you reinstall Windows 10, fresh, from now on - then take a backup of the WHOLE LAPTOP DRIVE to an external drive, using "Aomei Backupper" or "CloneZilla" (advanced users only)
#6 Use "Double Driver" to take a copy of ALL the drivers on the current Windows 10 install:
http://www.boozet.org/dd.htm and copy the driver backup to a safe place (USB key) - once you have done so and also have checked and double checked everything (and maybe made a SECOND backup of the ENTIRE DRIVE!) WIPE the drive, remove it, install that SSD (remember that SSD, right?) and then...
#7 Download the appropriate ISO that matches the architecture (64 bit, usually) and variant of Windows 10 which came with the machine.
#8 Using "Rufus"
https://rufus.akeo.ie and a flash drive (recommend SanDisk), create a bootable Windows 10 installer from the ISO.
#9 Install Windows 10 FRESH from the installer from step #8
#10 Get online and activate it - YOU DO *NOT* NEED "ANTIVIRUS" - Microsoft's own, built-in "Windows Defender" is ALL you need - others are an utter mess and usually a placebo these days, see "Security Now" on
http://twit.tv for more information (search around, you'll soon come up with affirmation.)
#11 Restore drivers from the "Double Driver" backup you took in step #6
#12 Listen to "The Tech Guy" and "Security Now" - these folks REALLY REALLY REALLY REALLY REALLY know what they're on about, more than most "engineers" I've heard over the years, second to NONE!
http://twit.tv - Leo Laporte and Steve Gibson, the rest are clueless hopefuls at BEST.
Enjoy a CLEAN install.
PS: I am running Windows 10 64 bit on a 7 YEAR OLD Lenovo ThinkPad R61, here, with 3GB RAM and a cheap SanDisk SSD
- it boots in 20 seconds and runs VERY well, and is only a Core 2 Duo. What saves it is the SSD!
