Is there any alternative way to use an DMM to do the job ?
Not really, but you could probably rig something up with a function generator and a scope. I believe the principle is the same as measuring the ESR of electrolytic capacitors. The Bob Parker ESR meter is often used for batteries with the protection diodes removed (they'd short the battery terminals).
