Author Topic: Burning in Headphones ? WTF ?  (Read 46639 times)
Offline dannyf
Re: Burning in Headphones ? WTF ?
« Reply #125 on: November 18, 2014, 11:43:23 pm »
there will be a performance increase after run-in.
Why?
The fact that the speaker will perform differently after run-in doesn't, by itself, lend to the conclusion that it will perform better.
Offline Mark Hennessy
    • My electronics and audio website
« Reply #126 on: November 18, 2014, 11:55:21 pm »
Why?
Sigh |O
If the designer is half-way competent, the enclosure will be optimised for the stable, "burnt-in" drive unit. Hence, the box will be non-optimum for the brand new drive unit. I fail to see how I could have been any clearer about this.
It's really simple. Get some data about drive units (as new and "burnt in"), enter their parameters into a modelling program, and compare the optimum enclosures for each case. Then, transfer the new driver into the box that is optimised for the burnt-in drive unit and look at the differences for yourself.
Offline suicidaleggroll
« Reply #127 on: November 18, 2014, 11:55:49 pm »
I thought Mark Hennessy explained it pretty well.
A speaker's enclosure and crossover network are designed and built for a specific combination of drivers.  The volume, shape, tuning frequency, crossover frequency, slope, etc. are all based entirely on the drivers' Thiele/Small parameters (T/S for short) and frequency response.  Speaker designers make sure that when they design the system, they use the T/S parameters for fully broken-in drivers, since that's how the speaker will spend the majority of its life.  This of course means that before the drivers are broken in, and the T/S parameters are out of spec, the enclosure, crossover network, and drivers are all mis-matched.  This can result in unnatural resonances and lulls in the response, a quicker-than-normal rolloff on the bottom end, some quirky behavior around the crossover frequency, etc.
Edit: too slow.
« Last Edit: November 19, 2014, 12:05:34 am by suicidaleggroll »
Offline tszaboo
« Reply #128 on: November 19, 2014, 12:08:34 am »
I agree that speakers/earphones may loosen up a little, though not as dramatic as people make out.
Though burning in DAC's etc is absolute nonsense!
Some two years ago, I've put together a small USB DAC with an output filter. I powered it up, put the sacrificial headphone on it, and it did not sound right. I was at the lab (workspace, lunch break), put a scope on it, and fired up the sinegen software. Ant there it was, strange clipping on the output on the positive side.
I went to the other room for a DMM when i returned, in front of my eyes the clipping disappeared, like something poped into it's place. It did not make this ever again. This wasnt 50 hour pink noise or whatever, just some 5 minutes, but it was there. Not everything audio related is bullshit.
Offline eV1Te
  • Your trusted friend in science!
    • richardandersson.net
« Reply #129 on: November 19, 2014, 12:25:56 am »
I would design the driver so that the material does not age to start with (this was maybe not possible 50 years ago when material selection was limited).
Sorry if I missed something written earlier in this thread, but I could not find any comparison of driver characteristics before and after they had been broken in, I did not find it in any datasheet from driver manufacturer when I checked a few.
Does anyone have data for any driver during the break-in period? I would be interested in knowing how big this effect is.
Offline dannyf
« Reply #130 on: November 19, 2014, 12:27:51 am »
Why?
That's probably too simplistic of a view.
I used to sit on the board of a fairly large pro-audio equipment manufacturer -  speakers, amplifiers and mixers + mics. I can tell you from personally experience that what you stated above cannot be further from typical design process in the industry.
You may want to think there is a lot of science in speaker design when in fact that's mostly an art.
« Reply #131 on: November 19, 2014, 12:55:56 am »
Why?
Why not?
Why?
In which case, it appears that there is a world of difference between large-scale pro audio and the better small hi-fi manufacturers in the UK.
I strongly disagree. That might have been valid in the 1970s, and that might have been your experience more recently than that - unfortunately - but today good designers will use the science to get them most of the way there. Good designers will use simulation tools extensively, and know how to interpret the results. Good designers are constantly refining their models and their science. Good designers design their own drive units from the ground up. Good designers might even design their own blends of polymers to make their diaphragms, rather than relying on "stock" polypropylene. But despite all this, good designers recognise that you can't do it on measurements alone, and subjective testing will be the final arbiter. The final 10%, if you will.
In my experience, at least...
« Reply #132 on: November 19, 2014, 01:12:34 am »
From my post on the previous page:
http://www.klippel.de/uploads/media/Aging_of_loudspeaker_suspension_Klippel.pdf
http://www.gr-research.com/myths.htm
Offline coppice
« Reply #133 on: November 19, 2014, 03:11:48 am »
The 5 minutes of bias needed to properly form an electrolytic cap, maybe?
Offline SteveyG
  • Soldering Equipment Guru
« Reply #134 on: November 19, 2014, 09:13:54 am »
Better instrument separation
The track was mixed in the studio. you can try all you want , but you will not be able to alter that mix
    A more open sound stage
thae recording studio had a certain size. try all you might, you cannot change the stage that was used from your home. it would involve hauling your butt to the recording studio and the usage of heavy equipment like bulldozers to alter that stage ...
You've obviously never heard the difference in sound stage between open and closed back headphones.
Also, please link in some of the speaker manufacturers who specify a burn-in time on their products. I want to make sure I'm doing it right!
My B&W speakers stated the burn in period, and also to avoid using them at high volume levels during that period.
« Last Edit: November 19, 2014, 11:40:44 am by SteveyG »
YouTube Channel: https://www.youtube.com/user/sdgelectronics/
Use code: “SDG5” to get 5% off JBC Equipment at Kaisertech
n45048
  • Guest
« Reply #135 on: November 24, 2014, 06:15:37 am »
My new solid wood headphones arrived today! I'll be sure to burn them in ;-)
Offline IanB
« Reply #136 on: November 24, 2014, 06:21:32 am »
What's the deal with all those seams on the plastic parts? It makes them look really cheap  >:D
n45048
  • Guest
« Reply #137 on: November 24, 2014, 06:26:05 am »
I assume you mean the stitching on the leather/pleather? How else would you design it?
Offline IanB
« Reply #138 on: November 24, 2014, 06:42:54 am »
No, I mean the ridges in the plastic from the moulding process. They make the product look poorly finished.
n45048
  • Guest
« Reply #139 on: November 24, 2014, 06:47:03 am »
Ahh. *shrug* It was a Kickstarter project, not bad for a first shot. They actually do sound rather nice and are very comfortable to wear.
Offline SteveyG
« Reply #140 on: November 24, 2014, 07:39:57 am »
600 ohm drivers I hope?
