Author Topic: Another Audiofool ?  (Read 6644 times)
Offline bilkoTopic starter
Another Audiofool ?
« on: June 11, 2013, 12:13:49 am »
So, now mains filtering now affects the audio quality. Should we ask our grid supplier to use gold instead of that oxidised steel cable to connect the overhead lines ?  :-DD
http://www.acoustica.org.uk/other/filter.html
Offline c4757p
  • adieu
Re: Another Audiofool ?
« Reply #1 on: June 11, 2013, 12:18:38 am »
This isn't new, these daft morons are all over the place. He even makes it look semi-legitimate at first by using something resembling a proper mains filter circuit, but it still has limited usefulness outside of SMPS designs.
Offline c4757p
  • adieu
« Reply #2 on: June 11, 2013, 12:24:56 am »
For the very best audio quality, you need a dedicated generator to power your equipment. The windings should be wound by hand from the finest high fidelity magnet wire ($5/ft) and the engine powered by gasoline cleaned by our special filters ($10 ea., replace daily). The dedicated circuit and the household mains wiring should not coexist in the same room, or harmful beat frequencies may develop between them, leading to a severe loss in high frequency response and a deep feeling of shame.
And no, gold wiring is not necessary, though the cables must be hermetically sealed to prevent corrosion; receptacles should have gold-plated contacts.
« Last Edit: June 11, 2013, 12:32:25 am by c4757p »
Offline peterthenovice
  • rip the other half out put in a bread board
« Reply #3 on: June 11, 2013, 12:33:19 am »
oh! not that rubbish. you need to run your hot and neutral on separate walls using our special gold lined silver platinum Germaniumdoped genitacly isolated and spliced bacteria grown in the pools of bird poop on the island Isola(virtual villagers).
a craftsman multimeter, bk precsion scope
Online xrunner
  • hp>Agilent>Keysight>???
« Reply #4 on: June 11, 2013, 12:34:55 am »
Oh I love looking at audiophile equipment - for a good chuckle.
Especially the speaker cables -
Only $1,200 for 8 feet.  :-+
Oh and check out the specs! Who doesn't love Cryogenically-treated, Laboratory-Grade UP-OCC (Ultra-Pure Ohno Continuous Cast) Copper!
AUREUS-2 SPECIFICATIONS:
    Geometry: Time-Aligned™ Multi-Core, Circular Array
    Conductor: 8-Conductor, Cryogenically-treated, Laboratory-Grade UP-OCC (Ultra-Pure Ohno Continuous Cast) Copper
    Dielectric: Ultra-low capacitance DuPont® Teflon® insulation
    Termination: Precision machined, proprietary Banana and Spade connectors with 24K Mil-spec direct gold-plated contacts
http://www.trueaudiophile.com/argentum-acoustics-aureus-2-speaker-cable/
« Reply #5 on: June 11, 2013, 12:40:39 am »
some of the cable can be 10,000 per foot
Offline c4757p
  • adieu
« Reply #6 on: June 11, 2013, 12:41:42 am »
I'll sell you some coat hangers large-gauge high performance audio cable for $256,000 per foot.
Online xrunner
« Reply #7 on: June 11, 2013, 12:46:45 am »
Hmmm ... is the copper impregnated with the proper amount of spin-oriented depleted uranium pairs?
Offline c4757p
  • adieu
« Reply #8 on: June 11, 2013, 12:47:27 am »
That's an extra $65,536.
« Reply #9 on: June 11, 2013, 12:53:17 am »
does it come with a one time use crystal aligner
Online xrunner
« Reply #10 on: June 11, 2013, 12:55:30 am »
Cool.
Money is no object provided the cable can efficiently send frequencies higher than any human can hear.  :-DD
« Reply #11 on: June 11, 2013, 01:06:39 am »
Cool.
lte
because you never know when you need to use your sound system cable for your microwave radio satellite
Offline c4757p
  • adieu
« Reply #12 on: June 11, 2013, 01:08:13 am »
No! No no no. Any use of these High Performance Cables at frequencies above 100 MHz can permanently entangle the atoms and destroy low frequency performance!
« Reply #13 on: June 11, 2013, 01:10:29 am »
while dropping all dsl/cable internet speeds down to 65k.
duskglow
  • Guest
« Reply #14 on: June 11, 2013, 01:18:20 am »
This thread reminds me of this site.
http://kalecoauto.com
Offline c4757p
  • adieu
« Reply #15 on: June 11, 2013, 01:25:53 am »
I have to admire the humorous simplicity of the 710 cap.
Offline c4757p
  • adieu
« Reply #16 on: June 11, 2013, 01:27:01 am »
« Reply #17 on: June 11, 2013, 01:37:19 am »
"Special return policy: If you are not 100% satisfied, you may return this product for a full refund, in no LESS than 30 days before you purchase it!"
