Author Topic: Audio hookup 4-wire PA system office  (Read 5090 times)
Offline edyTopic starter
    • DevHackMod Channel
« on: February 01, 2013, 03:42:32 pm »
Hi folks,
I"m trying to install a Sony receiver to play radio over an office PA that was just installed. See attached photos. From what I've read, the red/black is right and white/green is left. I am not sure whether both lines were used or just black/white. As you can see I have 2 cables each with 4 wires in them. But I don't know how they were connected to the PA.
There are 8 speakers total in the ceiling. Or 4 pairs. All I can assume is that there are 2 pairs joined in parallel on each cable. So 1 cable drives 4 speakers (2 on a red/black pair and 2 on a green/white pair). However speakers are all in different rooms so there is no real "stereo" effect anyways.
So if you see the attachment showing back of receiver, can I just hook up one cable with 4 wires to A and then the other to B? It is only 200W cheapo but I figure at worst it will just not be able to crank up volume. Could I damage anything like burn up receiver and/or speakers and/or volume pots?
Re: Audio hookup 4-wire PA system office
« Reply #1 on: February 01, 2013, 03:56:24 pm »
Update... I connected the pairs to A and B and A worked but B put receiver into protect mode. So I am trying now to figure out which speakers are working on the A and which are right/left and seeing what is causing the other 4-wire cable connected to "B" to trip protect circuit.
Offline David_AVD
« Reply #2 on: February 01, 2013, 09:43:33 pm »
Hooking some unknown wiring up to an amplifier output is never a good idea.  That speaker system could be low impedance or 100V (or 70V) line.
Have you tried measuring the resistance between each combination of 2 wires?  (Disconnected from amplifier of course!)  That's your starting point.
Offline willb
« Reply #3 on: February 01, 2013, 10:56:00 pm »
This.
You definitely want to know the total system impedance before you start, especially where you're dealing with a consumer grade amplifier/receiver. Most of them will not handle anything lower than 8 ohms.
Wouldn't surprise me if your system is 70/100V. It's very common in commercial PA applications.  If you're in doubt, take one of the speakers out, if there's a transformer, it's a 25/70/100V system.
« Last Edit: February 01, 2013, 10:59:15 pm by willb »
« Reply #4 on: February 01, 2013, 11:27:39 pm »
Hi everyone,
Thanks for the help and advice!!! I trouble-shooted my installation and figured it out as follows:
I had 3 pairs working (white/green cable 1, red/black cable 1, white/green cable 2). That ran about 6 or 7 of the PA speaker/pots. However there were 3 not working. The red/black on cable 2 would cause receiver to "protect" mode and make click sounds as if a relay was disconnecting and power off.
So I opened up the 3 speaker pots for volume control that weren't working.
I noticed in one of the rooms, there was a single thin strand from a white wire that was bridged to the green!!! See the photo... I moved it out of the way, but that little bugger was causing a short! Argh!
The tech that installed the system didn't push it in properly.
Go figure!
Now it's fixed, works like a charm.
Offline David_AVD
« Reply #5 on: February 02, 2013, 03:29:07 am »
And still no measurement of the resistance to determine the likely load on the amplifier?  Sigh...  It makes sounds so job done I'm guessing.   ::)
By the look of the volume controls they are low impedance type as the 100V / 70V ones are not usually stereo.
Some of those stereo units offer a "2x / 4x / 8x impedance multiplication" function so as to still present a reasonable impedance to the amplifier even when multiple units are hooked up in parallel.
