I picked up a Tektronix 2225 the other day for really cheap, but with the caveat that the first channel does not work. Channel 2 appears to work beautifully; I get nice, clean traces of the probe adjust output on the scope, so I know the horizontal sweep and triggering circuits work ok.
When I have a probe attached to Channel 1, I get nothing. If I set the coupling switch to GND, I get the flatline trace, but it will not move when I adjust the vertical position potentiometer.
Really, I only need one channel for the occasional hobbyist work I do, but it would be nice to be able to repair it and get both channels working.
Does anyone have any suggestions as to where the problem is in this scope? A bad vertical preamp or final vertical amplification stage?
