Author Topic: Panavise 350 jaw dimensions  (Read 712 times)
Offline Helix70Topic starter
  • VK4JNA
« on: February 14, 2020, 12:41:41 pm »
Can anyone with a Panavise 350 tell me what size the metal jaws are (the part that the neoprene soft jaws slide over).
I have a vise from a company called Royston Electronics that is about 40 years old and the jaws are stuffed. The Panavise ones look real similar.
The metal jaws on my vise are 38.1mm wide x 4.8mm thick (1.5 inches x 0.19 inches).
Offline aargee
Re: Panavise 350 jaw dimensions
« Reply #1 on: February 14, 2020, 10:21:32 pm »
I have an old Panavise here and it's roughly (in dim light with a steel rule) 37.5 x 4.5mm - so I imagine its pretty much the same. Royston may have just re-badged the Panavise gear?
The clamp material looks to be stamped out of steel plate.
« Last Edit: February 14, 2020, 10:23:56 pm by aargee »
Not easy, not hard, just need to be incentivised.
  • VK4JNA
« Reply #2 on: February 14, 2020, 10:31:07 pm »
Thanks for that, sounds close enough. I might buy a set of neoprene soft jaws from Panavise to see if they fit.
Offline Gregg
« Reply #3 on: February 15, 2020, 12:42:13 am »
Panavise 350 Jaws are 37.8mm wide x 4.56mm thick and 44.6mm tall (height where the rubber cover slides over the jaw) Width is +/- 0.5mm because the steel jaw pieces are sheared with rough edges.  Measurements taken with a genuine Mitutoyo digital caliper.
  • VK4JNA
« Reply #4 on: February 15, 2020, 07:10:08 am »
Thanks Greg. Sounds like I can make it work.
