Poll
Please rate based on overall experience. (This poll is just for the best. The Survey is below)
Arcon
Canicon
Capxon
Chhsi
Choyo
Cornell Dubilier
CTC
DST
Elite
ELNA
EPCOS
Evercon
Fuh Yin
Fuhjyyu
Fujitsu (FPCAP)
Gloria
G-Luxon
GL
Gsc
Hec
Hermei
Hitachi
I.Q.
Illinois Capacitor
JakeC
Jamicon
JDEC
Jee
Jpcon
Jun Fu
Kemet Corporation
Lelon
Licon
Ltec
Nichicon
Nkcon
Nrsy
Ost
Panasonic
Partsnic
Pce-tur
Raycon
Rubysun
Rubycon
SamXon
Sanyo/Suncon
Skywell
Stone
Supacon
Su'scon
Taicon
Tayeh
Teapo
Tocon
Toshin Kogyo
United Chemi-Con
Vishay
Wendell
Würth Elektronik
Yec
Author Topic: Capacitor Manufacturer Rating  (Read 3306 times)
Offline mafioTopic starter
« on: July 10, 2016, 05:10:30 pm »
The first link is a survey for capacitor manufacturers. Please rate based on overall experience. (will finish the EEVBLOG poll in a little bit)
https://surveyplanet.com/5782701726f371f8547b9d03
Some list of caps
http://www.badcaps.net/forum/showthread.php?t=388
http://www.tomshardware.com/reviews/power-supplies-101,4193-5.html
Let me know if I missing any common or large manufacturers.
IF YOU HAVEN'T USED DONT RATE.
Just good bad overall experience. I know it is a crap question but we are in the general discussion area.
« Last Edit: July 10, 2016, 09:44:28 pm by mafio »
Offline XOIIO
Re: Capacitor Manufacturer Rating
« Reply #1 on: July 10, 2016, 05:16:07 pm »
I've only heard of like, 5 of these brands?
Also hopefully nobody has an email that's none@none.com because that's my default for putting into these sorts of things.
The "value" is pretty arbitrary when you aren't giving any other info on how you want us to rate them.
Offline dmills
« Reply #2 on: July 10, 2016, 07:00:25 pm »
Yea, what does value mean here?
Besides I only have personal design experience with about 5 of those, all were just fine and the question really came down to who had what I needed at the right price and with stock available.
Now electrolytic caps are one of those things too easy to screw up, so I don't even tend to look at the stuff not from the big players with good history, sure I might miss a bargain, but lacking the ability to do full life cycle testing it just is not worth the savings in the volumes I deal with.
It is I suspect a slightly more fraught question when there is major volumes or major value engineering to hit target BOM in play.
Regards, Dan.
« Reply #3 on: July 17, 2016, 06:09:48 pm »
I will post the results to the survey after 15 or so contributions.
Offline ChunkyPastaSauce
« Reply #4 on: July 17, 2016, 06:31:06 pm »
I wanted to see the vote so I entered a random one (rubycon) before reading the first post....not realizing you can't remove a vote..sorry about that :palm:
Online wraper
  • Country: lv
« Reply #5 on: July 17, 2016, 07:08:23 pm »
There is no point or value in this poll if you can select only one answer as there are multiple top manufacturers which are on par. Even more, you put poly cap in the list  :palm: Also you listed United chemi-con but not Nippon chemi-con (United chemi-con is their North American subsidiary).
Fujitsu (FPCAP)
I've personally seen about 70% of those
« Last Edit: July 17, 2016, 07:10:21 pm by wraper »
