Author Topic: Anyone tried the cheap china coin cell batteries? (CR2032)  (Read 20931 times)
Offline PsiTopic starter
« on: October 21, 2011, 10:39:04 am »
So i need around 450x CR2032 coin cells for some led based ID tags i'm making for an event.
They're sold for quite cheap on ebay (out of china) for around $60 at that quantity.
They'll get used to run a couple of leds for 2 days so it doesn't matter if they have a high self-discharge rate for example.
Has anyone on here actually bought coin cells from ebay/china or know how crap they really are?
or how bad the capacity is? (its supposed to be around 225mAh)
Obviously at that price i don't except them to be as good as energizer/duracell brand.
Also quite a few ebay auctions say the batteries are "loose" anyone know what that actually means?
One would hope they don't just fill up a bag with them all loose to short on each other :(
« Last Edit: October 21, 2011, 10:45:53 am by Psi »
Offline johnboxall
  • You do nothing, you get nothing.
    • Books, services and more:
Re: Anyone tried the cheap china coin cell batteries? (CR2032)
« Reply #1 on: October 21, 2011, 10:57:36 am »
Don't bother with eBay - spring the extra and get real ones from Digikey
http://search.digikey.com/au/en/products/CR2032/P189-ND/31939
Free delivery as well (>$200). Win.
Offline sonicj
  • updata successed!
« Reply #2 on: October 21, 2011, 11:02:35 am »
i buy mine on eBay. i stick with US sellers and brand names. (sony, panasonic, etc.) they are cheap and no problems as of yet.
-sj
« Reply #3 on: October 21, 2011, 11:06:32 am »
hm.. i'd not considered digikey, looks like 400 of them would cost NZ$95 from digikey
Free shipping over NZ$125 but i need some other stuff anyway :)
That's a good option, thanks.
« Last Edit: October 21, 2011, 11:09:35 am by Psi »
Offline johnboxall
« Reply #4 on: October 21, 2011, 11:07:56 am »
Oh, sorry - thought you were in Australia. The little flag is too small for my eyesight :)
« Reply #5 on: October 21, 2011, 11:13:03 am »
heh, the batteries are cheaper than the battery holders
Offline mikeselectricstuff
    • Mike's Electric Stuff
« Reply #6 on: October 21, 2011, 11:53:00 am »
For a short event I'd go for the cheap ones, as long as you're not relying on getting anywhere near 100% capacity.
Day Job: Mostly LEDs
Offline Kiriakos-GR
  • Country: gr
  • User is banned.
    • Honda AX-1 rebuild
« Reply #7 on: October 21, 2011, 01:00:48 pm »
I do not give my vote to no-name coin cell batteries from China either.
This is why I get Maxell ones from ebay, as a minimum warranty of quality VS price.
« Reply #8 on: October 21, 2011, 01:23:56 pm »
i think ill go buy two cr2032's  one panasonic from a reputable store and one no-name brand from the local $1 shop/china-crap store.
Then i can run them both flat with an led and compare how long they last.
Atleast that will give me an idea of just how bad the china ones are compared to a brand name one.
Offline Conrad Hoffman
    • The Messy Basement
« Reply #9 on: October 21, 2011, 02:29:33 pm »
I admit it. I buy all my button cells at hamfests, on cards of unknown brand, age and quality. The last 2032 cells I got were "Thunderbolt", made in china for Harbor Freight (our junky import tool store). They seem as good as any. I also get regular batteries at the closeout stores like Big Lots and Dollar Store. The Chinese batteries I've gotten there actually seem to leak less than the brand names. I've done discharge tests and found no real difference in the energy content of the cells. IMHO, when you buy Duracell, Energizer or other big brand names, you're paying a lot for the name. The most important thing is whatever batteries you buy, they shouldn't be too old. Age is a killer for standard battery chemistries.
Offline Mechatrommer
  • Country: my
  • reassessing directives...
« Reply #10 on: October 21, 2011, 03:15:06 pm »
as mike said, if its for short period event, why care how long it will last? the user maybe just toss it afterward. if me, if the pay for that event is very good, then go for brand name without 2nd thought, but if the budget is so so, then go no name brand, but if you can afford to buy double quantity cheapo is better, to anticipate for some lemon (dead) cells OOB.
(edit: sorry thought its international... OOB = out of the box)
« Last Edit: October 21, 2011, 03:43:13 pm by Mechatrommer »
« Reply #11 on: October 21, 2011, 09:19:38 pm »
Not individually blister-packed.
De-blistering 450 batteries would suck.
Online Zero999
  • 0999
« Reply #12 on: October 23, 2011, 06:12:54 pm »
You may want to buy 10 of the cheap ones as consistency may be a problem i.e. some of them might be good and others junk.
« Reply #13 on: October 23, 2011, 10:24:26 pm »
good point.
Offline ThePranksta
    • Lattech Systems
« Reply #14 on: October 24, 2011, 07:03:17 am »
I've done a few CR2032 powered projects and have thus test a whole range of  cells in varying range of temperatures (-10C to 60C) typical for :
China No-Name: very quick voltage drop off; do not bank on a capacity higher than 160mAh.
Maxell and Energizer: quite good we approximate their capacity to 200mAh (they are rated at 220mAh)
Renata: Best of the bunch by far, could get 215mAh (rated 225mAh) out of them every time.
Also a number of the no-name cells "leaked".
Offline Simon
  • Global Moderator
    • Simon's Electronics
« Reply #15 on: October 24, 2011, 11:56:34 am »
i used batteries from our pound shop, they ran down in months - garbage
« Reply #16 on: October 24, 2011, 11:59:37 am »
In this application, if they have a high rate of self discharge it's not going to matter.
(Since they will be run flat over a period of 2 days)
