With virtually all electronics manufactured overseas and metric, it often makes me wonder what's going on with American tool importers and manufactuers. It's a fact of life with any service that you need metric tools as your primary tools. Yet, most all manufactuers sell primary sets as SAE. If anything, tool manufactuers here have been slowly paring down their metric offerings to abbreviated sets. You can buy limited nutdrivers and hex tools with gaps. Finding drills are virtually impossible unless you go mail order. Spanner sets are discontinuous. JIS crosspoint screwdrivers are almost impossible to find beyond 2 importers with Hozan being the primary in a #1 or #2. Companies like Snap-on, Stanley/Proto, and even the major Asian importers like Harbor Freight have comparitively little in the way of full metric despite their home field advantage. What gives? Everthing is Metric nowadays. Gaps in metric tools are explained away as the missing tools are unecessary due to standardization. Many commercial sets are missing 5.5,6,9,&12 nut drivers for example. Fractionals such as 4.5mm are rare outside of one Xcelite set and even the new company has been discontinuing a lot of the metric offerings. Japanese love the 12mm size on switch dress nuts. Another problem is deep pocket offerings in Metric. The SAE sizes are deep pocket, but the corresponing set of metrics are not. I just spent $80 USD on a Proto metric set that is only 1 1/2" deep while the exact same SAE set is continuous deep shaft.
Hardware is another issue alltogether. Try finding anything under 3 or 4mm here in any lengths or head types in machine screws. Washers and lock washers need to be nearest SAE sizes and often too thick with domestic production. Unless you go to Fleabay for imports, many metric fasteners are simply unavailable in replacement sizes. Even worse, try to find metric fine thread, secondary fasteners.
This doesn't make sense as everything here is imported, yet tool and imports keep being biased to SAE and limited to what industry appears to think as standards.
Is it the same outside this reactionary microcosm?
