Author Topic: What is the story behind " BRYMEN Tecnologies" DMM products ??  (Read 23444 times)
Offline Kiriakos-GRTopic starter
  • Country: gr
  • User is banned.
    • Honda AX-1 rebuild
Re: What is the story behind " BRYMEN Tecnologies" DMM products ??
« Reply #50 on: December 09, 2011, 01:33:43 am »
Ahh another blast of enthusiasm.  ;)
Today I got this nice function generator, and now I have the power to investigate for good the frequency range plus the data cycle.
And my first discovery is that Brymen lies in the specs of 1MHz max frequency, this goes to OL above the 7.39999MHz LOL  yea it does ..  ;D
(The generator is a bit off on the LCD counter at MHz, but its not my so to worry about it)
« Last Edit: December 09, 2011, 01:38:11 am by Kiriakos-GR »
Offline PetrosA
« Reply #51 on: December 09, 2011, 03:17:00 am »
Are you sure that the 1 MHz doesn't refer to AC voltage measurements?
I miss my home I miss my porch, porch
  • Country: gr
  • User is banned.
« Reply #52 on: December 09, 2011, 06:06:11 am »
alm
  • Guest
« Reply #53 on: December 10, 2011, 08:08:25 pm »
What's the amplitude, 0.6 Vrms? The bandwidth of a frequency counter is usually specified as the frequency where the sensitivity drops below the acceptable minimum, this does not mean it can't go higher if you feed it enough signal.
  • Country: gr
  • User is banned.
« Reply #54 on: December 10, 2011, 08:22:58 pm »
At my understanding the 0,6V are needed so to trigger the multimeter to read 100kHz.
