Just for 1.70 EUR
![Smiley :)](https://www.eevblog.com/forum/Smileys/default/smiley.gif)
# Double Blades, Coax Cable Stripper
# Fully Adjustable & Replaceable Blades
# Removable and adjustable 4, 6, 8 and 12mm Insulation
# Can set various cutting depths according to different cables
# Easy to use, lock the tool over the cable, spin clockwise, then pull off the unwanted portion
# Can be used for RG-58/59/62/6/6QS/3C/4C/5C
# Designed for RG-59, RG-59 Quad, RG-6, RG-6 Quad, and RG-58 Cables
# Comes with one screw driver
# Length:10cm
# Color: gray
Because it looks adjustable, I think that it will live longer than expected.
But I will be gentle with it too.
