I depotted an OPAMP LABS amplifier a few years ago to fix it. Steel case, resin encapsulated ( so responded well to a soak in acetone for a week) to get it apart to the point I could replace the cooked output transistors, diodes and resistors.
Replaced them with others, and it worked, though there were some track repairs needed, and the original ceramic decoupling capacitors did not survive the solvent. Opamp inside is a LM308, buried under that block of yellowing epoxy. Scary is that it was originally being used as a gain of 2 video amplifier, driving what was essentially a 7R5 load with video. Thus the upgraded transistors with cooling, seeing as the originals were some generic NPN and PNP 100ma devices. They had cooked themselves ( and the 2 diodes) into char, along with the 2R2 resistors.
