Has anyone had any success getting any real help from AI to read, parse, and answer questions about parts from their data sheets?
Given how relatively proficient ChatGPT seems to be in coding, I had reasonably high expectations that it might also be able to answer questions about components. In this instance, I found two ADCs from competing manufacturers, which have completely different part numbers but actually look as though one may have been designed as a pin compatible alternative to the other. They both come in the same package, have similar headline specs, and although many pins have different names (eg. "VCC" vs "AVDD"), their functions seem similar. Certainly there are too many similarities to be a coincidence.
This seemed like a good opportunity to get some help from AI. Ask it what the functional differences are, and whether they are in fact likely to be compatible.
Of course I can't trust the answers without checking, but if it notices that (say) one has a particular feature that the other lacks, that at least is something I can quickly look for in both data sheets. I often seem to find myself trying to compare and contrast similar parts, so any help in spotting differences is welcome.
To say I was unimpressed would be an understatement. ChatGPT (-o1 preview) failed to correctly identify the number of inputs or even the number of ADC cores in each part. Features clearly common to both were missed in one device, and highlighted as a point of difference. Each time I said "no, try again" it would apologise, correct its mistake, then make a bunch of new mistakes next time around. Stupid, obvious errors, like "pin X is called NNNN", where it just isn't.
In the end it was completely useless, and I gave up - but I do think this is an area where AI might one day help and save time.
Has anyone found an AI tool that does a better job of "understanding" data sheets and answering questions about them?
