But if you can just disable the converter going to those loads using the converter itself during their off period then the current can be minimal.
Ah.
That's the piece i wasn't thinking about.
Don't look for a converter that can produce 20uA output and consume as much itself, but just connect any good converter to power ONLY the big loads like the camera, RF and the SD card, while using an LDO for the uC.
When it's done, shut down the converter.
In other words, i finally got it why there are "shutdown" pins on the converter chips.
Hm. Best case scenario is twice the run time for the same battery count (or half the battery count, actually).
Practical numbers for now are 3 seconds at 100mA for the camera to stabilize and get a picture, then 13 seconds at 60mA to write the picture down.
4 joules per picture, if we ignore the RF.
That is, 56Wh per year, or 4 D cells with a converter.
I'm leaving it overnight staring out of the window again...
Yeah if you just force the lines on the powered IC to be LOW or INPUT mode when the SD is shut off then that problem goes away, but of course there are also isolating bus transceivers.
Only problem is, i have the RF module share the same SPI bus.
So, full disconnect necessary.
