Author Topic: One million RPM motor  (Read 11568 times)
Offline chickenHeadKnobTopic starter
« on: March 02, 2016, 11:25:52 am »
I found this youtube. It is in french but should be easy to  comprehend, of a guy who spins up magnets upto  1,000,000 rpm: https://youtu.be/RB7zzs9x5Og
Of course completely useless but I found it interesting. One of his little magnets grenades.
ETH Zurich claims a motor that actually can do effective work at this RPM, but I could find no video: http://www.livescience.com/3075-spin-record-set-1-million-rpm.html
Offline AntiProtonBoy
  • I think I passed the Voight-Kampff test.
Re: One million RPM motor
« Reply #1 on: March 02, 2016, 12:28:13 pm »
One of them shattered holy crap.
Offline hayatepilot
« Reply #2 on: March 02, 2016, 12:43:53 pm »
You can buy motors with 1 megarpm and 100W: http://www.celeroton.com/en/products/motors.html  :o
I don't want to know the price though.... :-X
They have to cost an arm and a leg.
Greetings
Offline ajb
« Reply #3 on: March 02, 2016, 02:16:56 pm »
100W at 1Mrpm, that's, what, a whopping 0.008 in*lbs ( 8 mil*lbs?) of torque?  I wonder what the power input requirement is to get 100W at the shaft.
Offline HAL-42b
« Reply #4 on: March 02, 2016, 03:17:42 pm »
Strange the standard configuration is with ballbearings and the magnetic bearings are offered only as an option. Didn't know ballbearings could run at such speeds either. They probably don't last very long.
Offline Kilrah
« Reply #5 on: March 02, 2016, 04:21:01 pm »
There are model jet engines that run at 250K RPM, without the heat and hostile enfironment it doesn't sound that far-fetched that there are bearings that can take 1M RPM...
Offline mikeselectricstuff
    • Mike's Electric Stuff
« Reply #6 on: March 02, 2016, 04:33:19 pm »
Would be cool to do it with a glass container under vacuum...
Day Job: Mostly LEDs
Z80
  • Guest
« Reply #7 on: March 02, 2016, 04:34:45 pm »
This looks like a high quality genuine product, but nowhere in the datasheet does it mention operation at 1e6 rpm?  The quoted operating figures are 500,000 rpm with 2 mNm torque @ 100W and 4mNm @ 200W with active cooling, still impressive.  Maybe marketing getting hold of the no load max speed or something.
« Reply #8 on: March 02, 2016, 10:16:04 pm »
Air turbine dentist drills routinely run at 100,000 or more when free running, but with almost no torque. The moment he bites into your tooth it spins down. The real trick is making a motor with grunt that doesn't dynamically disassemble itself.
Offline Brumby
« Reply #9 on: March 02, 2016, 11:48:34 pm »
I was thinking the same thing.
« Reply #10 on: March 03, 2016, 12:07:38 am »
It's only equivalent to 16.6666.... KHz.
Slow as, compared to things electronic.
Magnetic levitation bearings.
Most aren't aware a simple engine turbocharger runs to 150K rpm.
Offline Stonent
« Reply #11 on: March 03, 2016, 12:19:35 am »
My thoughts exactly!
Offline alho
« Reply #12 on: March 03, 2016, 12:28:38 am »
Ceramic ball bearings. Zirconium dioxide or aluminium oxide also used in dentist drills mentioned earlier.
« Reply #13 on: March 03, 2016, 01:31:02 am »
hmmmm - I happen to have a vacuum pump somewhere....
Offline HAL-42b
« Reply #14 on: March 03, 2016, 01:43:00 am »
Are you guys trying to design a London Moment Gyroscope or something?
« Last Edit: March 03, 2016, 01:46:54 am by HAL-42b »
Z80
  • Guest
« Reply #15 on: March 03, 2016, 10:02:32 am »
More holes in the ceiling  :-+
Offline dexters_lab
« Reply #16 on: March 03, 2016, 10:05:29 am »
Offline joeqsmith
« Reply #17 on: March 03, 2016, 10:36:35 am »
That's impressive!  I like the cooling system too.
