Author Topic: High Voltage Linear Regulator  (Read 6723 times)
Offline dannyTopic starter
« on: December 16, 2009, 04:53:26 am »
I am looking for this particular part number VB408 TO-220 package
but the part is obsolete, I couldn't finde one selling here in the US
Does anybody know what is a good substitute for this one
please advice.
thanks
danny :)
Re: High Voltage Linear Regulator
« Reply #1 on: December 16, 2009, 04:56:39 am »
GeekGirl
  • Guest
« Reply #2 on: December 16, 2009, 05:07:08 am »
http://www.supertex.com/pdf/datasheets/LR8.pdf Is a posibility, depends on the max current you are drawing and the package.
« Reply #3 on: December 16, 2009, 05:14:37 am »
Thanks for the quick reply.
I'm not sure  how much is the exact current drawing
the part is defective, unable to make measurement.
I will try to check the specs on LR8
Thank you very much geekgirl  :)
Offline Simon
  • Global Moderator
    • Simon's Electronics
« Reply #4 on: December 16, 2009, 06:36:48 pm »
what are you powering with it ?
« Reply #5 on: December 20, 2009, 02:03:30 am »
It is used on a LINN preamp power supply  :)
Offline Simon
  • Global Moderator
« Reply #6 on: December 20, 2009, 08:24:23 am »
sounds like 1 amp will be all you need to supply, do you know the Vin and Vout ?
« Reply #7 on: December 21, 2009, 02:52:13 am »
I have to look on the schematics to see if there are any voltages mentioned
usually if the power supply failed we replace it with a new one.
but since the whole supply is so expensive then component level is the other options.
will keep you guys posted
