I'm using a 0.7X Barlow lens and it's just barely enough distance to work with ( 5" or 13 cm ). Consider a 0.5x lens or find a store that lets you test the difference.
Quote from: Neganur on June 26, 2012, 04:26:58 pmI'm using a 0.7X Barlow lens and it's just barely enough distance to work with ( 5" or 13 cm ). Consider a 0.5x lens or find a store that lets you test the difference.MoiCan you tell the difference on the distance for the working area with and without the barlow lens ? I was looking for a store that will let me test the lenses, but the one I visited few years ago is out of business, now everything is pretty much on the internet.David.
Can you change the vertical working area on a microscope by changing the eyepieces ?
