Author Topic: "Passive Wifi" created using an FPGA consumes uW of energy.  (Read 2595 times)
Offline StonentTopic starter
« on: February 24, 2016, 08:13:53 pm »
This was a very interesting read on some innovative stuff they came up with at the University of Washington.
They were able to build an 802.11b wifi device in an FPGA without any analog hardware and were able to cut power consumption from 100's of mWs to uWs.
It seems to be centered around moving more functionality from the client, to the Access Point.  So that the wifi Access Point is doing the work of determining when it is ok for a device to start transmitting rather than the client monitoring doing the work.
They seem to be doing some of this passive communication in side areas of the wifi channels which won't have as much interference.
Story: http://www.networkworld.com/article/3037088/mobile-wireless/researchers-make-low-power-wi-fi-breakthrough.html
Published Paper: http://passivewifi.cs.washington.edu/files/passive_wifi.pdf
« Last Edit: February 24, 2016, 08:20:18 pm by Stonent »
Offline nwvlab
    • next-hack.com
Re: "Passive Wifi" created using an FPGA consumes uW of energy.
« Reply #1 on: February 24, 2016, 09:06:02 pm »
Very interesting indeed!
I hope that a standard will be set-up!
Offline scatha
« Reply #2 on: February 24, 2016, 09:18:02 pm »
Pretty cool - it modulates a passive out-of-band CW by altering the antenna impedance to create backscatter. I'm surprised at the kind of ranges they're getting out of it.
Offline coppice
« Reply #3 on: March 09, 2016, 08:51:36 am »
Remember that the range for 802.11b was pretty good compared to the modern 802.11 specs. There is a price to pay for greater bit rate, even when you use a more efficient transmission scheme. For the pretty optimistic case of the CW transmitter, sensor and receiving station sitting in a line the range doesn't look too bad, but for more general positioning its not so great. Those (d1^2)*(d2^2) losses really add up. They talk a lot about the power needed to transmit, but don't say much about receiving at the passive node. The power taken by receiving is quite considerable, and a node which cannot receive sounds rather limited. It must have been a very interesting project to work on, but I suspect it will have limited application.
« Last Edit: March 09, 2016, 08:57:55 am by coppice »
Offline rrinker
« Reply #4 on: March 09, 2016, 01:52:55 pm »
 I can see all sorts of uses for a transmit-only device - in things like sensors of all sorts. Door and window sensors, presence detectors, pretty much anything. Those sort of devices don't have to receive anything, and the lower the power they need to consume the better, as such devices are usually battery powered. If you can get near shelf life out of a set of batteries, it just makes using these as purely wireless devices that much better.
Offline Tinkerer
« Reply #5 on: March 10, 2016, 12:04:17 am »
Very fascinating.
Put a small rechargable battery in there with something like a small solar cell and you are almost going to have unlimited power as long as it catches sun for a bit each day. Bet a small solar cell would generate 10x more energy than that thing uses at any given point.
