Gk, that's beautiful! Excellent work. A+
Thanks!
If you are trying to measure current and have high voltages, watch out for leakage.
According to the datasheet for the Electrolube CPL, the insulation resistance is 1 x 10
12 ohms/cm, though I guess the real figure would depend on how thickly you layer it on.
http://www.farnell.com/datasheets/392349.pdfThere are more expensive coatings, such as the Electrolube HPA:
http://www.farnell.com/datasheets/316960.pdf..... which has a quoted insulation resistance of 1 X 10
14 ohms/cm, but the cheaper stuff is quite fine for most applications.
It's anyones guess as to what's in the can from Jaycar though.
