Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
General
General Technical Chat
"Floating" Copper Pours on PCB - LED Thermalplane
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: "Floating" Copper Pours on PCB - LED Thermalplane (Read 3460 times)
Frequent Contributor
Country:
on:
January 31, 2013, 11:17:05 am »
Hi all,
I have designed an LED strip (300x20mm) which consists of 3 LEDs plus some resistors/Zeners and a connector. The LEDs have a thermal pad which I have connected to large copper pours (essentially fill both side of the strip) on both the top and bottom of the PCB. The thermal plane is stitched together directly under the thermal pads on the LED with vias as well as through other holes. The thermal performance is very good and there are no problems there. However I have been thinking about EMC and floating copper pours. Should I connect the thermalplane to ground? (Assuming this has no effect on LED operation). The LEDs are driven by a ~350mA C.C. 230Vac flyback supply.
Best Regards,
Dave
Logged
(United Kingdom)
vlf3
Guest
Re: "Floating" Copper Pours on PCB - LED Thermalplane
Reply #1 on:
January 31, 2013, 04:00:20 pm »
Have you monitored on a radio, LF to HF Short-wave bands for any RFI being emitted... however, it might be a good option to ground the PCB plane, since any AC present will radiate along the LED strip, and find it's own resonance.
Logged
Corporate666
Supporter
Country:
Remember, you are unique, just like everybody else
Reply #2 on:
January 31, 2013, 06:36:07 pm »
Have you looked at the LED datasheet for info on this? I've seen some specifically mention that the thermal pad should not be connected to ground.
If that's not an issue, I don't see why connecting to ground would hurt.
Logged
It's not always the most popular person who gets the job done.
SeanB
Super Contributor
Country:
Reply #3 on:
January 31, 2013, 06:57:17 pm »
If it is connected to an internal part of the die ( very common to have it be part of the one lead) then use a small 1n or so ceramic capacitor and a 1M chip resistor in parallel to connect it to the one power lead, so as to prevent radiation from it.
Logged
Country:
Reply #4 on:
February 01, 2013, 09:38:16 am »
I have checked the datasheet and the pad is electrically isolated from the anode/cathode. I have decided to connect the thermal planes to ground.
I now have another silly question...should I connect the mounting holes to ground too? The PCBs will sit on an earthed metal tray.
Logged
(United Kingdom)
Country:
Reply #5 on:
February 01, 2013, 10:16:07 am »
I am thinking I should isolate them as this could introduce common mode noise?
Logged
(United Kingdom)
Print
Search
Pages: [
1
Go Up
« previous
next »
General
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
