I have a bit of a side question to this... When a datasheet states "tolerant", does this mean that it is perfectly fine to run the part at whatever spec it is declared "tolerant" to, or is it "tolerant" in that it can take that specced value, but it is not the intended mode of operation and there could be some consequences such as reduced life, change in other specced values, etc?
