TL;DR - well that's just rude! But you can skip to the bottom section if you are so inclined
I've recently started a video blog (no uploads yet - going to get a handful put together before I upload them) at the suggestion of a friend who found my random tinkerings and experimentations interesting.
The audio is recorded on a Samson Go mic (which I bought ages back for an underground noise (wait - does that count as "seismic"?) series of experiments) - and I'm happy with the audio.
The video quality on the other hand... well just now I'm recording on three devices (simultaneously) - 2x Motorola Moto G (2nd Gen) - and an Amazon Kindle Fire.
All these devices output 720p at 26FPS... eeeh... kinda. Actually, the FPS is variable - if I transcode it the video gets weird in places - if I don't, syncing up the audio needs to be done multiple times (pretty much every time I speak) - which is a PiTA!
So with that in mind, I can either find a workaround or upgrade the recording hardware.
Given that I am just starting out - there is absolutely no point in buying an expensive camera: for all I know I'll get bored after five videos which nobody watched anyway! - which limits me to cheap hardware (which I consider <£100)
Memories of bad video footage makes me shudder: we've all seen bad youtube videos with creakey audio, shakey, poorly lit footage and a cat doing something cute with a hamster and a sweater - and rampant capitalism has taught me to associate cheap recording equipment with that bad footage!
Once I got past that initial disgust - I started to wonder - are they all that bad? I have a good microphone: which would usually be my biggest complaint with cheap recording equipment (I'm
looking at listening to you, mobile-phone footage!)
I am going to try an experiment tonight with my Raspberry Pi's (original) 5MP camera (which can run 1080p@30FPS or 720p@60fps) to see if I can get better results (though, it does lack lenses... hmmm... that probably won't be an issue actually - it's not like I'm being artsy!)
And that finally brings us round to the crux of the matter: bearing in mind that I have decent audio recording capability - would a sub-£100 camera capable of 1080p@30fps (like
this, just for argument's sake - there are cheaper options too) be good enough to get me off the ground - or would the video improvements from that be a false economy over my existing cameras? What are the "cons" of a cheap/low-end digital camcorder?
