If you're having board problems I feel bad for you son.I got 99 problems, but a switch ain't one.The year is 94 I need voltage to fallAnd all over my project: Kirchoff's motherfuckin' law.I got two choices yall raise impedence ORCut the power in half, throw some batteries on the floor.Now I ain't trying to see no arcs or sparks today,Plus I got a few resistors I can lower the rateAt which these amperes flow to get the coulumbs low,I think, "Why I'm try'na change this expression fo'?Because it's a one not a zero don't want an LED to glow,Plus ain't no logic gates to invert the output yo.Am I doing things right or should I change some code?I don't do wiring diagrams so sometimes I don't know.Maybe we engineers need to lower the barFuck that I got an academic rep I can't afford to mar.For a second I thought to quit that much I can admitUntil I realized I just had to tweak my wiring a bit.Regulate this switch bounce keep them volts controlled not whackBut all engineers know you need capacitors for that. So throw one in parallel, little capacitance or somethingJust like point oh two(.02) farads or somethingThat clears things up lowers voltage a bitEnough that an LED in series won't always be lit.I could've stopped current and it makes me feel dumbI got 99 problems but a switch ain't one.
