Author Topic: 50G ohm Retirement Fund  (Read 8254 times)
Offline pguerra75Topic starter
« on: March 14, 2017, 07:50:28 pm »
I was recently cleaning up shop in an electronics warehouse and came across an interesting find. A plastic bottle of approx. 26000 loose 50g Ohm 30% resistors (0805) package. I did some research and the cheapest I can find these things is around $2 at volume. So essentially I found $52000 worth of parts that almost no one will want. One can only laugh.  :-DD
Just thought this crowd might enjoy that.
Offline alm
Re: 50G ohm Retirement Fund
« Reply #1 on: March 14, 2017, 08:44:43 pm »
I wonder what kind of PCB cleaning you would need to keep parallel leakage down for such a small package. Put guard traces around the pads? Mill a narrow slot under the resistor?
Online Benta
« Reply #2 on: March 14, 2017, 09:31:48 pm »
Rattling around in a bottle, you can be pretty certain that they are not 50 Gohm anymore.
Offline Codebird
« Reply #3 on: March 14, 2017, 09:41:12 pm »
I can't imagine what anyone would even want with such a part.
Online Benta
« Reply #4 on: March 14, 2017, 10:17:49 pm »
Yes, the customer base is limited, to say the least. Not where I'd put my retirement fund.
Offline ZeTeX
  • Country: il
  • When in doubt, add more flux.
« Reply #5 on: March 14, 2017, 10:36:34 pm »
Pictures? :D
Online jpanhalt
« Reply #6 on: March 14, 2017, 11:25:11 pm »
List them on eBay as "vintage."  What have you got to lose?
Offline TerraHertz
    • It's not really a Blog
« Reply #7 on: March 14, 2017, 11:43:19 pm »
Huh, that's amusing. Since I need some 10G and 20G surface mount resistors.
Too bad paralleling them up probably won't work so well, since the surface leakage would be additive, cleaning more difficult, and greater overall parasitic capacitance.
For why I need some, see https://www.eevblog.com/forum/repair/restoring-a-mass-spectrometer-maybe/
Anyway how much for about 100 of them? (And are you aware you shouldn't handle them with bare fingers?)
« Reply #8 on: March 15, 2017, 12:24:58 am »
Not gonna charge anyone do to the fact I don't know their history. PM me your address and I'll ship them over, and yes I am aware :P
Pictures? :D
Haha, I should list them individually, haha.
« Reply #9 on: March 15, 2017, 12:27:16 am »
Nor can I but I am a bit of an impostor EE.
Offline raspberrypi
« Reply #10 on: March 15, 2017, 01:58:27 am »
How did you figure out the quantity? Weight?
I'm legally blind so sometimes I ask obvious questions, but its because I can't see well.
« Reply #11 on: March 15, 2017, 02:33:28 am »
I had a local jewler weigh a sample of 100 and then the lot.
Offline MarkS
« Reply #12 on: March 15, 2017, 02:54:12 am »
50G Ohm? 50 giga-Ohm?
Offline Bryan
« Reply #13 on: March 15, 2017, 05:34:09 am »
For what application what would a 50Gohm resistor be used for?
-=Bryan=-
Offline boffin
« Reply #14 on: March 15, 2017, 06:26:33 am »
You sure they're not caps?
I say that due to the colour, sort of a yellowish which is pretty common with ceramic caps.
« Last Edit: March 15, 2017, 06:30:51 am by boffin »
Offline nitro2k01
« Reply #15 on: March 15, 2017, 08:14:20 am »
If you have nothing better to do, hook up say 100 of them in parallel and see if it checks out to about 500M, which would be a more easily measurable value. Or hook up a few of them in parallel and see if they measure as a capacitors I guess. I have a hard time seeing where something like a 50G ohm resistor in such a small package would be useful. Maybe in something that is potted, but then again just the resin would probably contribute a not insignificant stray resistance. So hmm...
Would love to see a "teardown" of it though. Maybe polishing one layer at a time off of it to reveal its internal structure. Maybe send the whole bag, or a carefully selected sample, to mikeselectricstuff?
Offline AndyC_772
« Reply #16 on: March 15, 2017, 09:25:50 am »
Factory rejects. They were supposed to be 10k, but someone forgot to apply the metal film and just left the ceramic substrate.  :-DD
The following users thanked this post: thm_w, james_s, harerod
Online Alex Nikitin
  • Femtoampnut and Tapehead.
    • A.N.T. Audio
« Reply #17 on: March 15, 2017, 09:31:49 am »
Electrometers. At work I routinely use 20G and  100G resistors and plan to use SMD parts of these values in a near future. The application in my case is Quadrupole Mass Spectrometry. Similar electrometers are used in many other applications where very small charges/currents have to be measured or sensed. The current noise level is reduced with the increase in the resistor value, so larger the value, lower the noise (but slower the response due to a parasitic capacitance). 20G resistor has about 1fA RMS self-noise in 1Hz BW. 50G resistor - about 0.6fA.
I can also add that it is perfectly possible to use SMD parts with these values. If somebody would like to know the details, than the ADA4530-1 datasheet, evaluation board description and AN-1373 application note can provide a good starting point.
Cheers
Alex
Offline tszaboo
« Reply #18 on: March 15, 2017, 09:36:28 am »
Preatty much, what I would have said. 50Gohm on a pcb in a 0805 package is a part not soldered in...
Offline alm
« Reply #19 on: March 15, 2017, 09:43:19 am »
Well, 50 GOhm resistors do exist in 0805 (up to 100 GOhm in that series). Make sure you do not exceed that 1/8 W power rating ;).
Online tggzzz
« Reply #20 on: March 15, 2017, 10:56:28 am »
... especially when staying within the max voltage rating!
« Reply #21 on: March 15, 2017, 05:17:09 pm »
Yup, verified it all with test equipment.
« Reply #22 on: March 15, 2017, 06:18:00 pm »
Just head an Idea, who things I should glitter bomb Dave with 26k SMD resistors?   >:D
Offline rsjsouza
  • Eternally curious
    • Vbe - vídeo blog eletrônico
« Reply #23 on: March 15, 2017, 06:46:02 pm »
pguerra75, if it is not inconvenient for you I would have some use for a portion of these resistors. I sent you a PM yesterday.
The following users thanked this post: Trader
« Reply #24 on: March 15, 2017, 07:29:24 pm »
Feedback resistor in a transconductance amplifier for measuring nano/picoamps. One of these would give you 0-5V out for an input current of 0-100 pA.
