Author Topic: 4 1/2 DC Digital Panel Volt Meter  (Read 3780 times)
Offline Kiriakos-GRTopic starter
  • Country: gr
  • User is banned.
    • Honda AX-1 rebuild
« on: June 17, 2010, 08:15:51 pm »
Well I had start looking for one of those ... 4 1/2 DC  Digital Panel Volt Meter
On ebay it looks that there is 2-3 deferent designs ,  but I can not tell from the pictures or the generic specs , witch one are the most accurate or successful ..
I am thinking to add one in parallel with my Laboratory PSU , as it has analog meters.
It passed from my mind to get an old branded bench meter , and use it as volt meter.
But I noticed that all those famous  old bench meters , has terrible response times.
Even the worst Chinese  4 1/2 DC  Digital Panel Volt Meter , looks to updates 4 times per second.
I have spotted  this two options , and still looking .
If any one has any tips , just add them .
http://shop.ebay.co.uk/virtualvillage-uk-rho/m.html?_nkw=4+1%2F2+DC+++Digital+Panel+Volt+Meter+Tester&_sacat=0&_odkw=4+1%2F2+DC+20V+Red+Digital+Panel+Volt+Meter+Tester&_osacat=0&bkBtn=&_trksid=p3911.m270.l1313
http://shop.ebay.co.uk/virtualvillage-uk-rho/m.html?_nkw=19.999V+DC+Voltmeter+&_sacat=0&_odkw=DC+Voltmeter+Digital+Panel+Meter&_osacat=0&bkBtn=&_trksid=p3911.m270.l1313
My interest are about something that could do like  0-35 V  at full resolution ...  all of those could do 19.999 V
« Last Edit: June 17, 2010, 08:17:26 pm by Kiriakos-GR »
Offline saturation
  • Doveryai, no proveryai
    • NIST
Re: 4 1/2 DC Digital Panel Volt Meter
« Reply #1 on: June 18, 2010, 12:25:48 am »
You are thinking of replacing the analog meters on your Kenwood PSU, are you K?
I don't remember fully, but those analog meters are very high quality, and although not as many digits as a digital, its supposed to read accurately as best as analog could ever be.
Best Wishes,
 Saturation
Offline joelby
« Reply #2 on: June 18, 2010, 12:48:35 am »
How many times per second do you change the voltage on your power supply? If you're using it as an AC power source by turning the knob back and forth 50 times a second, you're doing it wrong.
I saw a site where someone bought the cheapest digital multimeters he could find, cut the range switch part of the circuit board off and fixed up the tracks, and attached that. I think it worked out much cheaper than buying a dedicated voltmeter module.
« Last Edit: June 19, 2010, 04:56:14 am by joelby »
  • Country: gr
  • User is banned.
« Reply #3 on: June 18, 2010, 12:45:30 pm »
Thanks  S ... I am aware that the originals are high quality meters ..
Thats why I made an alternative move , that so far, it turned out well ...
If everything goes well , I will add it above it ..  ;)
https://www.eevblog.com/forum/index.php?topic=718.0
Well @joelby you did not fall far out of my secret alternative plan ..  ;)
  • Country: gr
  • User is banned.
« Reply #4 on: June 19, 2010, 04:04:18 pm »
Check out this pictures ..  its an bad example of quality of construction ...  Its not my ,
but some one got it in Greece for 10 EUR ..
Offline saturation
    • NIST
« Reply #5 on: June 19, 2010, 07:30:25 pm »
Thanks for the photos, K.  It looks bad because its very likely hand soldered; it uneven and some joints look cold, like C5 R6.  There also appear to be a fingerprint just above the number 6135 on the second photo.
If you use it at its best operational range, such a meter won't be too bad if it reads accurately.
Best Wishes,
 Saturation
