So I purchased one of the Assembly Specialist breadboards, the full size SS252 model (the breadboard by itself without the metal mounting plate), and had a bit of a surprise.
It's the breadboard by itself without the metal mounting plate.I should mention that I've never used or seen one of the 3M breadboards before, so I didn't think to look out for this.
It turns out that the bus rows along the sides aren't spaced 0.1" apart like I expected. This isn't a fault in any way of the product itself, just that I have one of
these SparkFun Breadboard Power Supply Sticks which are designed to plug straight into a breadboard. And in this case, they can't.
As an aside, I also, for some reason I can't quite remember, purchased one of Assembly Specialist's DS293 "3-row Distribution Strip 6 rows of 6 connected 4 tie-point terminals", and the rows on that
are spaced 0.1" apart. I wonder if the same is true for the 2 row version, which would make it different from what comes in the full size breadboard.
Again, not a complaint about the product. Just an unexpected finding.
I also wonder what breadboard SparkFun designed that power stick for. I have one of those brand-x-in-an-orange-box breadboards and it doesn't fit in that either. While the adjacent bus rows on that are 0.1" apart, the rows on opposite sides of the board don't linen up with the mount points on the stick.
(Edited for clarity)
