Author Topic: Stabistor diode STB523 - anybody got a datasheet?  (Read 7879 times)
Offline david77Topic starter
« on: June 24, 2012, 09:32:18 pm »
I've been looking online all day to find some info on a stabistor diode STB523. Had no luck so far.
Has anybody got any info on this part? It's used in a HP power supply.
HP part no. 1901-0460
Offline free_electron
    • SiliconValleyGarage
Re: Stabistor diode STB523 - anybody got a datasheet?
« Reply #1 on: June 24, 2012, 11:22:33 pm »
If memory serves me well that's a diode stack: a bunch of diodes in forward mode ( not a zener ! ) 15 volts made by General Electric.  looooong gone ...
the difference with a zener is that it does not conduct in reverse.
 a zener in reverse acts like a diode : 0.7 volts drop . stabistors don't do this. i homebrew these using a simple 1n4007 and a 14.3 volts zener. works fine
  Z14.3v     1n4001
Fixing a 6236A ?  ;D
« Last Edit: June 25, 2012, 02:43:16 am by free_electron »
« Reply #2 on: June 25, 2012, 06:36:37 am »
Fixing a 6236A ?  ;D
Not exactly. I am thinking about building one from scratch.
So you just put the 14,3V Zener and the 1N4007 in series, anode to anode? Which side represents the anode and kathode of the original STB then?
No, hang on I think I can answer that myself: Kathode is kathode side of 1N4007, anode is anode of 1N4007, too. Right?
The dash in the second line is not important, I take it?
Thanks for your help, much appreciated.
« Last Edit: June 25, 2012, 06:46:18 am by david77 »
Offline Shuggsy
« Reply #3 on: November 22, 2012, 05:38:35 am »
Sorry to dig this up from the grave, but I think this just became relevant to me as I am indeed fixing an HP 6236B!
I'm hoping you can help me understand the STB523 diode a little more free_electron (or anyone else feeling the need to comment... ;)). If I have things straight, it's merely a stack of diodes that has a threshold of 15V before it begins conducting when forward biased? This opposed to the 0.7V like a 1n4007 or similar?
I pulled one of these out of my supply because the current limiting behavior started at a lower output current that it should have on my supply and one of this is in the circuit. Testing it on my bench, it started conducting around 1.8V when forward biased... so if it's supposed to have a threshold/forward voltage around 15V then this one is definitely headed to the trash bin and I'll be taking free_electron's advice on how to home brew one! 8)
Any help is appreciated!
Offline poorchava
  • Troll Cave Electronics!
« Reply #4 on: November 22, 2012, 07:10:45 am »
I think this is simply 21 diodes in series. For a current to pass through these, the voltage has to exceed the sum of forward voltage drops. Stabistors are supposed to be better for low voltage references. One example of such device is BAS17 (google for datasheet). I think that hacking up 21 1n4148's in series won't necessarily do the trick, because stabistor is optimized to have the voltage drop varying very slightly when current changes.
EDIT:
googled that one up:
http://www.circuitsonline.net/forum/view/76899
« Last Edit: November 22, 2012, 07:19:34 am by poorchava »
Offline Jebnor
  • Absolutely! Yes, kind of, sort of, not really, no.
« Reply #5 on: September 24, 2014, 08:12:45 pm »
Fixing a 6236A ?  ;D
I'm thinking about doing the same thing. Well the 6236B.  Did you complete your project by chance?
Before this, there was a typo.
Offline calexanian
    • Alex-Tronix
« Reply #6 on: September 24, 2014, 10:27:18 pm »
Voltage reference devices took over for those many moon ago. Chris Gammel was making a joke about them earlier. Stabistor. The most violent component or something like that.
Charles Alexanian
Alex-Tronix Control Systems
Offline scanny
« Reply #7 on: July 06, 2015, 02:31:54 am »
For anyone encountering this thread on search, the expected forward voltage drop of the HP part 1901-0460 is indeed around 1.9V. So the one @Shuggsy had was good.
There are a few of them in my HP 6281A which I just happened to be searching on, so thought I'd mention for anyone else who finds this thread.
Offline schopi68
    • My stuff page
« Reply #8 on: July 19, 2015, 04:20:24 pm »
The Service Manual for the HP POWER SUPPLY PP-7548 lists the STB523 HP-Part no. 1901-0460 as a 1N4830 (which has 3 PN-junctions).
Offline Ecogeek
« Reply #9 on: August 19, 2021, 08:53:32 pm »
Service Manual HP power supply HP6256_HP6263_HP6264_HP6265_HP6266_HP6267_HP6271B_HP6274B_dc_power_supply. I found my two STB523 (CR8, CR36, diode, Si 3-junction, HP 1901-0460) Stabistors measured 2.1V in the working power supply. The exact voltage does depend on the current flowing and temperature, so the real-world circuit measurement is useful.  Thanks for the reference to 1N4156 part being the equivalent which does have a downloadable datasheet. Even this reference on Wikipedia; at least something on the subject.      https://en.wikipedia.org/wiki/Stabistor
https://www.digitroncorp.com/getmedia/824DFFAE-F11A-451C-A8DF-65A92EFB02A5/1N4156-2c-1N4157-2c-1N4453-2c-1N4829-2c-1N4830-2c-1N5179-2c-MPD100-MPD400A.aspx?ext=.pdf
Hopefully, this is information is helpful to others working on vintage lab equipment.
Online floobydust
« Reply #11 on: August 21, 2021, 12:57:00 am »
1901-0460 replaced by 1901-0468 Microsemi Corp for HP P/N: DZ890505C but I got no farther.
Offline Wallace Gasiewicz
« Reply #12 on: August 21, 2021, 02:15:13 pm »
How about this reference?
Same as ecogeek
1901-0460    01973       STB523-A
01973  is  GE Co. Semiconductor Prod. Dept.
I think you already know this but the information is from this group, which I have found to be quite helpful:
HP parts list on Groups.io   HP-Agilent-Keysight-equipment,    maybe they could help further
Offline 5065AGuru
« Reply #13 on: August 23, 2021, 03:25:18 am »
The HP 5065A also uses a 1901-0460 in the lamp exciter.
I have a replacement stock of the 1N4830 that is equivalent.
Cheers,
Corby
