I purchased this 2 weeks ago to transfer my laptop HD to a SSD.
https://www.amazon.ca/dp/B07F7WDZGT?ref=ppx_yo2ov_dt_b_fed_asin_title&th=1Note that it powered an HD fine as long as I plugged it into a USB3.0 plug. (Note that this was a laptop 2.5inch HD)
It could only power a SATA SSD when plugged into both a USB2.0 and USB3.0 port on my laptop.
EG: On the HP Pavilion DV6 laptops, the usb ports on the left side are USB3.0 which can deliver 3 amps at 5v. On the right side, the usb ports are USB2.0 and can only supply 1amp at 5v.
If you are using a home PC, it would probably be best to use the rear USB jacks soldered right to the motherboard where there are no iffy cable extensions to a case mounted USB jack.
This version comes with an AC wallwart power cable :
https://www.amazon.ca/dp/B07JGT17B8/ref=twister_B07JPHL136?_encoding=UTF8&th=1I realize you are looking for an all PC powered version.
