The VA rating must be larger than the VA of the load.
Remember the power always remains the same. 70W of power is always the same regardless of the line voltage or current combination.
So if I was you I would look for a (110 primary / 230VAC secondary) step up transformer, that is capable of delivering 70Watts or greater just to be safe. So a few calculations: VA = Watts of power (at unity power factor).... so the VA needs to be 70VA or greater. I would just go with 100VA to be on the safe side.
Also don't forget to fuse the thing with a 1 Amp or less fuse.
