I have several lithium battery packs that output 5-22v on a DC barrel jack.
I spliced together a cable that fed my last laptop 20vdc from this and if you didn't mind looking at heat shrink, it worked fine/
Well, I just upgraded my laptop. The new one has a smaller plug (the hp blue tip) and I don't have a single damn tip that fits this beast. Why on earth they need to make so many random tips is beyond me.
You'd think all possible geometries of barrel connectors had already been discovered by man, but I guess not.
I could source barrel tips, and remake my splice job with the new style.
But this thing can also charge via usbc. I used a usbc meter to verify it takes 19.8v in. so, 20v nominal probably. so I got to thinking.
It would be of greater utility to me, to have a usbc style connector than this new barrel connector.
so I googled for dc-in to usbc adapter. And nothing.
I found plenty of usbc-in to dc barrel output. But I need the reverse.
Yes. I know that it wouldn't work to charge phones that need 5/9v. That's fine. It'd probably need to buck down to 5v to perform negotiation. My 20v power banks also have a usba 5v port on them that's concurrently live with the variable output port, so that might help here too.
Is there a better forum for usb-c hacking than here?
