Author Topic: Ariane 6 maiden launch live broadcast.  (Read 3089 times)
Online coppercone2
Re: Ariane 6 maiden launch live broadcast.
« Reply #50 on: July 17, 2024, 09:07:48 pm »
For something as simple as a loose wire, it often can work just peachy for a long time until you bump it, or it gets some serious current. It will run forever at nominal conditions without a stimulus of some sort (or 2 years of thermal expansion and contraction if it survives the postal service). But if you catch that sucker smouldering, it can be tightened and good forever.
People running sane burn in programs include some form of shock, from whacking with rubber mallets to vibrating the product in patterns. They usually ensure the burn in includes at least some temperature variation as well. However, some people think production testing is about cosseting a product, so the flaws don't show up. Fire them. :)
they get the raise and the praise not a firing  :(
Online coppercone2
« Reply #51 on: July 17, 2024, 09:09:46 pm »
I am curious about burn in on CRT tv's. Did they do it? It has a sane component count. Since the phosphors is just a canvas, and the beam steering does the work, so its just a few very nice amplifiers.
Online coppice
« Reply #52 on: July 17, 2024, 09:46:42 pm »
The Japanese started burn in for TVs and other consumer electronics in the 1970s. When they started building in European factories, and arranging JVs with existing European makers to build in European factories, the practice spread. People found there were financial improvements from the lower level of warranty claims.
