I used to build things like that, all discrete parts, because that's all we had. When I began, the 555 timer was just designed, and the most often used IC was the 741 op amp. Now, you can build it, just for looks and nostalgia.
Interestingly, some appliances do come with transparent cases, so you can appreciate the guts, the Pickit 3 comes to mind.
